587,997 active members*
1,963 visitors online*
Results 1 to 16 of 16
    Sep 2016
    26
    Bridgeport boring issues
    I have a Bridgeport J Head mill that I converted to a cnc. Installed ball screws on the x, y and z. I doubled checked my calibration on all axis and all is good.
    I am using the Masso G3 Touch with these stepper motors, https://www.automationtechnologiesin...sbridgeportkit
    Well every time I try to bore a hole in aluminum or steel it does not come out as a circle more like a freehand circle.
    Since then I replaced my spindle bearings, shimmed my x and y gibs. I haven't looked at my knee gib yet.
    I tried just doing hole boring after I did all the above with no luck.
    I am running the spindle at 2720 rpm with a 8mm end mill and using a mister for lube and air.
    Is there anything I could try or look at?
    Thank you for the help, Nathan
    Apr 2004
    5752
    Re: Bridgeport boring issues
    Are you doing this boring with an endmill? Is everything but the Z axis locked down when you're doing it? Boring bars usually have a cutter like those in a lathe. Are you trepanning these holes with an endmill rather than boring them? Are you moving in Z with the knee, or the quill?
    Andrew Werby
    Website
    Sep 2016
    26
    I am boring with an end mill using the quill as my z.
    Dec 2013
    5716
    There are so many possibilities here it is difficult to know where to start. And I am just guessing here due to the limited information provided
    Mechanical
    Backlash or binding
    Overloading the motors
    Electrical
    Bad Signals/noise
    Tool path/G Code
    Feed rate
    Too aggressive tool path
    Overall technique
    If the machine is accurate otherwise, then I would have a serious look at how you are 'boring' holes. I suspect you are pocketing rather than boring, which is done with a boring head. Pocketing is done by interpolating with an endmill. It is good practice to rough pocket the hole, leaving about 0.5mm material, then finish contour with a helix tool path.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2016
    26
    Mechanical
    Backlash or binding, No
    Overloading the motors, Not Sure
    Electrical
    Bad Signals/noise, No
    Tool path/G Code
    Feed rate
    Overall technique
    I have attached the G code..
    (Bore)
    (MACHINE)
    ( VENDOR BRIDGEPORT)
    ( DESCRIPTION 3-AXIS)
    (T1 D=8. CR=0. - ZMIN=-9.53 - FLAT END MILL)
    N10 G90 G94 G17
    N15 G21
    (BORE1)
    N20 M5
    N25 T1 M6
    N30 S2720 M3
    N35 G54
    N40 G0 X13.824 Y-22.692
    N45 Z15.
    N50 G1 Z2. F3177.
    N55 Z0.8
    N60 G18 G3 X13.024 Z0. I-0.8 K0.
    N65 G1 X12.624
    N70 G17 G2 X11.824 Y-21.892 I0. J0.8
    N75 X23.824 Z-0.349 I6. J0.
    N80 X11.824 Z-0.698 I-6. J0.
    N85 X23.824 Z-1.048 I6. J0.
    N90 X11.824 Z-1.397 I-6. J0.
    N95 X23.824 Z-1.746 I6. J0.
    N100 X11.824 Z-2.095 I-6. J0.
    N105 X23.824 Z-2.444 I6. J0.
    N110 X11.824 Z-2.794 I-6. J0.
    N115 X23.824 Z-3.143 I6. J0.
    N120 X11.824 Z-3.492 I-6. J0.
    N125 X23.824 Z-3.841 I6. J0.
    N130 X11.824 Z-4.19 I-6. J0.
    N135 X23.824 Z-4.54 I6. J0.
    N140 X11.824 Z-4.889 I-6. J0.
    N145 X23.824 Z-5.238 I6. J0.
    N150 X11.824 Z-5.587 I-6. J0.
    N155 X23.824 Z-5.937 I6. J0.
    N160 X11.824 Z-6.286 I-6. J0.
    N165 X23.824 Z-6.635 I6. J0.
    N170 X11.824 Z-6.984 I-6. J0.
    N175 X23.824 Z-7.333 I6. J0.
    N180 X11.824 Z-7.683 I-6. J0.
    N185 X23.824 Z-8.032 I6. J0.
    N190 X11.824 Z-8.381 I-6. J0.
    N195 X23.824 Z-8.73 I6. J0.
    N200 X11.824 Z-9.079 I-6. J0.
    N205 X23.824 Z-9.429 I6. J0.
    N210 X21.496 Y-26.637 Z-9.53 I-6. J0.
    N215 X14.152 Y-17.147 I-3.672 J4.745
    N220 X21.496 Y-26.637 I3.672 J-4.745
    N225 X20.374 Y-26.494 I-0.49 J0.633
    N230 G1 X20.129 Y-26.178
    N235 X20.065 Y-26.095 Z-9.523
    N240 X20.003 Y-26.014 Z-9.503
    N245 X19.942 Y-25.936 Z-9.469
    N250 X19.885 Y-25.862 Z-9.423
    N255 X19.831 Y-25.793 Z-9.365
    N260 X19.783 Y-25.731 Z-9.296
    N265 X19.741 Y-25.676 Z-9.217
    N270 X19.705 Y-25.63 Z-9.13
    N275 X19.677 Y-25.593 Z-9.036
    N280 X19.656 Y-25.567 Z-8.937
    N285 X19.644 Y-25.551 Z-8.834
    N290 X19.64 Y-25.545 Z-8.73
    N295 Z5.
    N300 X39.756 Y-22.692
    N305 Z2.
    N310 Z0.8
    N315 G18 G3 X38.956 Z0. I-0.8 K0.
    N320 G1 X38.556
    N325 G17 G2 X37.756 Y-21.892 I0. J0.8
    N330 X44.756 Z-0.262 I3.5 J0.
    N335 X37.756 Z-0.524 I-3.5 J0.
    N340 X44.756 Z-0.786 I3.5 J0.
    N345 X37.756 Z-1.048 I-3.5 J0.
    N350 X44.756 Z-1.31 I3.5 J0.
    N355 X37.756 Z-1.571 I-3.5 J0.
    N360 X44.756 Z-1.833 I3.5 J0.
    N365 X37.756 Z-2.095 I-3.5 J0.
    N370 X44.756 Z-2.357 I3.5 J0.
    N375 X37.756 Z-2.619 I-3.5 J0.
    N380 X44.756 Z-2.881 I3.5 J0.
    N385 X37.756 Z-3.143 I-3.5 J0.
    N390 X44.756 Z-3.405 I3.5 J0.
    N395 X37.756 Z-3.667 I-3.5 J0.
    N400 X44.756 Z-3.929 I3.5 J0.
    N405 X37.756 Z-4.19 I-3.5 J0.
    N410 X44.756 Z-4.452 I3.5 J0.
    N415 X37.756 Z-4.714 I-3.5 J0.
    N420 X44.756 Z-4.976 I3.5 J0.
    N425 X37.756 Z-5.238 I-3.5 J0.
    N430 X44.756 Z-5.5 I3.5 J0.
    N435 X37.756 Z-5.762 I-3.5 J0.
    N440 X44.756 Z-6.024 I3.5 J0.
    N445 X37.756 Z-6.286 I-3.5 J0.
    N450 X44.756 Z-6.548 I3.5 J0.
    N455 X37.756 Z-6.81 I-3.5 J0.
    N460 X44.756 Z-7.071 I3.5 J0.
    N465 X37.756 Z-7.333 I-3.5 J0.
    N470 X44.756 Z-7.595 I3.5 J0.
    N475 X37.756 Z-7.857 I-3.5 J0.
    N480 X44.756 Z-8.119 I3.5 J0.
    N485 X37.756 Z-8.381 I-3.5 J0.
    N490 X44.756 Z-8.643 I3.5 J0.
    N495 X37.756 Z-8.905 I-3.5 J0.
    N500 X44.756 Z-9.167 I3.5 J0.
    N505 X37.756 Z-9.429 I-3.5 J0.
    N510 X40.041 Y-18.61 Z-9.53 I3.5 J0.
    N515 X42.471 Y-25.175 I1.215 J-3.282
    N520 X40.041 Y-18.61 I-1.215 J3.282
    N525 X41.069 Y-19.083 I0.278 J-0.75
    N530 G1 X41.208 Y-19.458
    N535 X41.244 Y-19.556 Z-9.523
    N540 X41.28 Y-19.652 Z-9.503
    N545 X41.314 Y-19.745 Z-9.469
    N550 X41.347 Y-19.833 Z-9.423
    N555 X41.377 Y-19.914 Z-9.365
    N560 X41.404 Y-19.988 Z-9.296
    N565 X41.428 Y-20.053 Z-9.217
    N570 X41.448 Y-20.107 Z-9.13
    N575 X41.464 Y-20.151 Z-9.036
    N580 X41.476 Y-20.182 Z-8.937
    N585 X41.483 Y-20.201 Z-8.834
    N590 X41.486 Y-20.208 Z-8.73
    N595 Z15.
    N600 M30
    Aug 2009
    1573
    ...try mill cutting a 45 degree angle for test with the same cutter
    Dec 2013
    5716
    I think this might be your problem
    N50 G1 Z2. F3177
    Try setting F = 300
    I'm surprised your machine is not walking across the floor at 3177
    From the post format, it looks to me like you are using Fusion 360.
    Choose 2D pocket as your roughing operation, and 2D contour as the finish operation.
    Make my life easy here and tell me what size hole you are cutting?
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2016
    26
    N50 G1 Z2. F3177
    Try setting F = 300
    I lowered the feedrate and I tried 300 down to 160 and that didn't fix my issue. It got a little better but not 100%. I did adjust the knee gib but haven't tried it. Plus I do have servos now and will be removing the stepper motors.
    Dec 2013
    5716
    Quote Originally Posted by usajet View Post
    Servos are good
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2016
    26
    I have my servos and I want to set them up what do I have to do?
    Dec 2013
    5716
    Install the motors on the machine.
    Mount the drives in your electrical cabinet
    Wire the drives to the motors, power, and your controller per the documentation supplied with the servo system
    Confirm proper operation
    Tune the system.
    Make chips.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2016
    26
    I replaced the steppers with servos and it still stops during milling process at 12 o'clock, 3 o'clock, 6 o'clock and 9 o'clock. Plus the circles are still not round.
    Dec 2013
    5716
    Rather than run a Bore operation, make the same cut with a Contour operation with the Ramp check box checked on the Linking tab. Around a 2 degree ramp. Should give you about the same tool path, but the G code is much different. Maybe your controller will like that better.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2016
    26
    I redone the backlash with the servos and no more problems with the circles. Thanks for the help.
