588,117 active members*
4,796 visitors online*
Results 1 to 3 of 3
    Jun 2011
    10
    Mach 3 post problem
    Just wondering if anyone using mach 3 has run into this problem using Dolphin?
    I imported my DXF, run the contour in the cam, no problem. Did the post using the mach 3 post processor. When i load it into my machine, I get an error message.."Radius from end of arc differs from radius from startline 20".
    I'm thinking it's an issue with the X,Y arc offset but not sure..
    Dangerous Guitar neck plates
    http://www.unofficialwarmoth.com/index.php?topic=12426.0
    Dec 2003
    259
    In Mach3 go to Config > General Config and check that arc's are set to Incremental and then try that.
    John S.
    Jun 2011
    10
    Quote Originally Posted by John S. View Post
    John S.
    Yes, IJ mode is set to incremental...
  1. Mach 3 Problem
    By juniormint in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-24-2010, 03:05 AM
  2. Rhinocam1/Mach 3 Post-processing problem
    By prdp141 in forum Rhino 3D
    Last Post: 01-14-2010, 02:29 PM
  3. Mach 2 Mach 3 Post Processor
    By IntarisiaQ4 in forum Australia, New Zealand Club House
    Last Post: 10-17-2009, 11:50 PM
  4. Anybody had this problem in Mach 3?
    By pointcloud in forum Mach Mill
    Last Post: 07-13-2007, 02:09 PM
