588,484 active members*
5,271 visitors online*
Results 1 to 10 of 10
    Feb 2010
    LSK problem with my fanuc
    Hi all,
    I have Fanuc 6T-A controller when I try to load a program into my fanuc memory I do the following :
    1-set the lock key to write(unprotected memory)
    2-set the mode selector key to EDIT
    3-Press the READ key
    4-set the lock key to LOCK.
    This is what I do to cnc, but this does nothing, I read before that when the CNC is ready to receive the information of the program, the initial LSK cominezan to flicker but this kind are not to be done.
    I do all the setting required like:
    Parameter
    000 bit 5 = 1
    026 bit 7 = 0 (the bit on the far left) should be a "0" so the control will send Xon/Xoff signals
    002 bit 5 = 1
    024 bit 0 = 1 (for 2 stop bits)
    025 :1 1 1 0 1 1 1 1 (4800 )
    under SETTING : Punch code = ISO, INPUT DEVICE 2 = 1
    Feb 2008
    15
    After you hit the read key what happens? Are you "setting the lock key" right after hitting read?
    2932
    After step 3 does LSK flash?
    You should then go to the PC and send the program.
    Don't do step 4 until the program has finished loading.
    Do you get any alarms?
    Where did you get those parameter numbers? I'm looking at a 6T-B manual. I wouldn't think they would be that different from a 6T-A... do you have a 6T-A manual?
    Parameters for 6T-B:
    #340 (IDVICE) = 2 (RS232C; set parameters for baud rate, etc. in PRM #311)
    #340 (IDVICE) = 3 (RS232C; set parameters for baud rate, etc. in PRM #312)
    #341 (ODVICE) = 2 or 3 (as above)
    #007 bit 7 (ICR) = 1 (LF is punched for EOB) = 0 (LFCRCR is punched for EOB)
    #009 bit 1 (REDT) = 1 (Storage of proram to memory is started by pressing CYCLE START in EDIT mode.
    #311 bit 0-3 = 1001 (Baud Rate 4800)
    #311 bit 4 (STP2) = 1 (2 Stop Bits)
    #311 bit 5 (RZSBC2) = 0 (Control Codes DC1 ~ DC4 are used)
    #311 bit 7 (NFED2) = 0 (Feed is not punched)
    Feb 2010
    LSK didn't falsh any time !!
    some times I got alarm no 085
    I don't have fanuc 6t-A parameter manual and I got these parameter from net
    note that also fanuc 6t-A have only 160 parameter
    Yes fanuc 6t-B parameret is different from 6t-A
    LTS,
    not thing change after I hit Read key!!
    thanks all
    Feb 2008
    15
    Are you using a pc and cable that work elsewere? Do you have any more 6TA controls that work?
    Feb 2010
    hi LTS,
    I use my computer on other fanuc machine and it is work,i don't have other 6ta controller
    I think my problem is why LSK not flashing?
    Feb 2010
    HI ALL,
    I try again to load a program into memory following these steps:
    when I hit the read key An edit label is appear beside LSK label on CRT tube!!
    Any one can help?
    thanks
    Aug 2007
    796
    Look here http://www.cnczone.com/forums/showthread.php?t=66857
    there is photo of proper setting of jampers in the first post
  1. Fanuc PML-L&M Problem
    By taspunsaen in forum Fanuc
    Last Post: 07-01-2022, 05:24 PM
  2. fanuc 10m problem
    By wayneman in forum Fanuc
    Last Post: 04-11-2012, 07:15 PM
  3. Fanuc X-OC EDM problem
    By JoBwan in forum EDM Discussion General Topics
    Last Post: 06-17-2009, 12:46 PM
  4. Fanuc 18M oil problem
    By mustafaguler in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2008, 08:35 AM
  5. FANUC-OM ATC Problem
    By Stebedeff in forum Fanuc
    Last Post: 07-27-2007, 04:18 PM
