588,542 active members*
5,113 visitors online*
    May 2009
    15
    bridgeport series 2 interact 4
    Hello I had a bad 24 volt power supply(this is the one on the right as you face the side cabinet)coutant hsh60u-13 and I had a guy try to fix it with a generic he had and I dont think he knew what he was doing and created different errors. He told me to send control to heidenhain (tnc 2500) and 350.00 bucks later was told control was perfect x!!##$$*. I am starting back at square one and I went ahead and bought the correct one off e-bay but I didnt see how the wires came off the original. Does anyone have one of these beasts and tell me what wires go where. And could you give me the correct tool holder and retention knob size. The manual said iso 40 is this the same as a cat 40? P.s I have a maintenance manual and parameters for control if I can make copies to help anybody.
    Nov 2004
    3028
    Attached is a Bridgeport service bulletin 277 that may answer your question.
    George
    Attached Files Attached Files
    May 2009
    15
    Thanks That'll give me a good chance of figuring it out!
    Jul 2005
    Interact 4 series 2 parameters
    Hi dcchip
    I purchased this gigantic beast a few months ago and can't wait to get machining! it has a broken power supply on the back of the tnc 145 I have built my own PSU out of atx psu and extra bit of my own, and now it is up and running I need parameters could you post yours please
    Thank you in advance there doesn't seem to be parameters anywhere for the interact 4?
    You will Really pull me out of the sticky stuff :cheers:
    Jonny
  1. Bridgeport Series II Interact 2 problems
    By gugu in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2014, 05:20 AM
  2. Bridgeport Series 2 Interact 2 Feedback
    By jaytam in forum Bridgeport / Hardinge Mills
    Last Post: 09-06-2009, 04:28 PM
  3. bridgeport interact 4 series 2
    By gideon233 in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2009, 03:05 AM
  4. Bridgeport Series 1 interact tnc 145
    By jaztau in forum Bridgeport / Hardinge Mills
    Last Post: 10-20-2008, 10:12 AM
  5. Bridgeport Series 1 Interact
    By zorba99 in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2008, 01:59 PM
