588,554 active members*
5,406 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Chuck will not open
Results 1 to 14 of 14
    Dec 2007
    48
    Chuck will not open
    okuma ospl5020l when i hit the foot pedal or try mdi chuck will not open or close. does anyone know what may be causing this . thanks for any help.
    Apr 2010
    Any Okuma tech will probably tell you its a RU1 board.
    Feb 2009
    6028
    Any Okuma worth his salt will tell you that for sure! Common problem. You can buy a RU1 from Okuma, think they are about 800.00 bucks, or I know a guy that does them....
    Must be a Cadet
    Feb 2003
    349
    Quote Originally Posted by bruiserba View Post
    to be sure, spindel should not running to open.
    1.if you had a part in for longer Time and it opens not the chuck, give mor psi
    2. if its not open in normaly mode, i have had this on an Lb15 some times and it was just a simple Relay (sitting in the back door).
    Dec 2008
    3142
    Tailstock not fully retracted ?
    ie limit not tripped
    Diagnostic page give any info ?
    Dec 2007
    48
    this guy can press something in the back of the machine and the chuck will open and close. but when u press the foot pedal or mdi nothin happens.so this sounds like a RV1board bad.
    Mar 2009
    1982
    I wouldn't say without investigation. There is diagnostic message. If You try M83 is for chuck clamp, M84 unclamp in MDI mode, You will see message on diagnostic screen.
    There could be a lot of reasons. Faulty pulse generator, for instance, and OSP doesn't knows, that spindle revolution stopped.
    Feb 2009
    6028
    Sounds like a RU1 to me, unless he is pushing on the solenoid. That is the most common failure on the RU1. Still need to check everything else to make sure.
    Mar 2009
    1982
    I agree 100%. I would like to add, that the RU1 is not absolute name of relay set. You need to find these relays. The name of relay is displayed on diagnostic message if any. Single Relay could be replaced. Must be re-soldered on RU1. There are also solutions with relays sitting in the connectors, easy check and easy change.
    Apr 2009
    1262
    Sometimes it's in Machine Lock! DOH! don't forget the simple things...
    Try it in MDI using M83 and 84 like Algirdas says. If it works in MDI you may have severed wires in your footswitch (happened here 2 weeks ago) or a bad connection. Look in Check Data to see if you are getting the input from the footswitch.
    Best regards,
    Jan 2010
    96
    As mentioned by some of the others Keep It Simple. Check your inputs and outputs in check data. First check and see if you have either the chuck closed or open input being made, one or the other should be made depending if the chuck is opened or closed. If not then start there. See if you get the input from the footswitch when pressed. If these are good then check the output to fire the chuck when the pedal is pressed. If the output is being fired then check the wire at the solenoid to see if you have voltage there. This will confirm if your RU1 board is working. If the output is firing but no voltage at the solenoid then check the wiring in between. If you have voltage at the solenoid then maybe a bad solenoid. You can check the output voltage at the RU1 board as well. Do this before you just up and order an 800 dollar board for nothing. If all this checks out then the chuck may be phyisicaly bound up or frozen. You will typicaly find the answer in one of these areas. Good Luck
    Mar 2011
    23
    Re: Chuck will not open
    Quote Originally Posted by CNCZILLA View Post
    I have same problem with my LB15 chuck not open or close , but this is happen randomly time to time , i did check valve and solenoids looks them working ok , cant open and close in MDI, looks its problem in the relay board on the back door , this is the RU board ?? not sure where the problem is , any ideas ?
    thanks
    Peter
    Feb 2009
    6028
    Lb 15 probably won't have the Ru1 board, early machines used ICE cube relays.
    Sent from my SM-T813 using Tapatalk
    Mar 2011
    23
    Quote Originally Posted by underthetire View Post
    I think some of those relays are responsible for control solenoid valves
    I find 2 relays that could control ,I will replace them with new ones from RS and see what happens ,otherwise i have no idea what wrong
  1. Replies: 17
    Last Post: 06-21-2021, 02:10 PM
  2. Chuck open signal needs to be reversed
    By Don18P in forum Fanuc
    Last Post: 01-07-2013, 04:44 PM
  3. Chuck open output signal
    By Don18P in forum Daewoo/Doosan
    Last Post: 12-30-2012, 07:12 PM
  4. run lc 30 with open chuck
    By martin269 in forum Okuma
    Last Post: 07-08-2012, 05:05 AM
  5. Replies: 3
    Last Post: 10-04-2011, 01:50 PM
