588,556 active members*
4,751 visitors online*
Results 1 to 6 of 6
    Jan 2004
    93
    Fanuc 0i-MC ethernet card
    Hello all,
    I have just ordered a machine with the 0i-MC controller. It comes without the ethernet option. I was wondering if a standard PC ethernet card will fit or is it a special Fanuc card? If it is a special card, what does it normally cost?
    the 0i-C has a few different options
    1. FANUC PCMCIA Card (generally reserved for Fanuc use)
    2. Fast Ethernet Board
    3. High speed Data Server
    http://www.jinpu-usa.com/PDF_Files/s...ure_gfa633.pdf
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    May 2009
    181
    no you cant put anything in there..
    but i should have an embedded port which is slower..
    The 0i-C series doesn't have embedded ethernet function on it, only the 0i-D has it.
    Best option, like Mystic Monkey says is fast ethernet board.
    In the Uk it is a £1400 optional board and software.
    The Fanuc Support Center Team
    www.fanuc-support.com
    Jan 2004
    93
    Thanks, guys! Very useful information!
    Best regards
    John
    Jan 2010
    99
    does the fast ethernet board option allow the exact same program-retrieval options as the embedded ethernet option on other controls??
    (not using data server of course)
    ie: with embedded ethernet, you can:
    [edit] mode (i/o chan 9)
    <prog>
    O1 <OPTR> <+> <Read> <Exec>
    to retrieve file "O0001" from the FTP server
    is this the same procedure with the fast ethernet board? (except maybe i/o channel)
    i assume the slow way (optr, host, embedd is similar except with "board" instead of "embedd")
    thanks
    - gwarble
  1. Fanuc 21i MB ethernet interface
    By mudassser in forum Fanuc
    Last Post: 09-16-2008, 06:51 PM
  2. ETHERNET CARD - NET GEAR ISA EA201
    By SpeedMetal in forum Milltronics
    Last Post: 02-06-2008, 10:16 PM
  3. Fanuc ethernet embedded 21i-MB
    By RoberChile in forum Fanuc
    Last Post: 12-31-2006, 07:09 PM
  4. Fanuc OM ethernet connection
    By Porknar in forum Fanuc
    Last Post: 09-25-2006, 03:11 PM
  5. Ethernet Communication with Fanuc 18i-T
    By smabhyan in forum Uncategorised CAM Discussion
    Last Post: 10-22-2003, 04:45 PM
