I just picked up a Light Machine Company Pro-Light 1000 mill w/ATC. It has a black control box which houses the PSU and drivers. I didn't get the computer interface card with it but wouldn't use it anyways. I plan on converting it to Mach3 and still keep the control box and original circuitry. So far I'm liking what I'm seeing with optocouplers protecting computer interface, TTL level I/O, and the use of name brand ICs. I've already began creating a schematic for the box and even have Mach3 controlling some motion on the mill.
What I lack is the basic knowledge of the original computer software and its interaction with the mill. Since I've never used it I don't know what all to look for in the interface. There are 25 signals of which I have about a dozen figured out. So if anyone can answer these questions or has any information they thing would be helpful please post.
Questions:
What can the software detect from the mill? So far I've found the following:
--x/y/z home.
--x/y/z limit.
--lid open.
--e-stop button.
What can the computer control on the mill? So far I've found the following:
--x/y/z direction.
--x/y/z movement.
--enable
--half step/full steps
Can the software switch on/off the Acc2 plug independently?
Can the software switch on/off the Acc3 plug independently?
Can the software control the RPMs of the spindle?
Does the software display the RPMs of the spindle?
Is there anyone with this machine and access to an oscilloscope that can measure the pulse width it produces to the steppers? It seems to need ~15us or more to properly trigger but it could just be a grounding problem on my test setup too.
When powered on and enabled are the steppers suppose to have power to them to "lock" them in place? This makes them produce a slight hum noise even when not moving.
Which way does the machine home? Is the bed to the back or front, left or right?
Anyone know the pitch of the ball screws or the gearing of the stepper to ball screws? It is belt driven and uses 200 step steppers.
Are the ports on the saddle with the ball bearings in them for oil?
Is 10w30 non-detergent oil good enough?
Where does one oil the spindle bearings?
And most importantly, is there anything I should know about this mill in the care/use department?
Thanks!
