588,531 active members*
8,473 visitors online*
Results 1 to 7 of 7
    Jun 2005
    15
    image -> machining
    I'm wondering if there is a program out there that can convert an image into a 3d model based on the colour. for example using the grey scale in a black and white image to extrapolate the different hights of different sections.
    I'm trying to make some engraved art out of some drawings.
    any suggestions are totally welcome.
    the road to eternity is always behind the next car.
    Apr 2003
    1873
    Sounds like this may fit your needs.
    MeshCam:
    http://www.grzsoftware.com/
    Jun 2005
    15
    PERFECT!!! Thank you soooo much
    35538
    If you're using Mach2 to run your machine, it can do it as well, but you won't have as much control as MeshCAM gives.
    Jun 2003
    20
    Rhino 3 can do this. It's called 'Heightfield from Image'. You can download a fully functional copy of Rhino 3 (limited to 25 saves) and try it out.
    Shine on,
    RayDOsity
    Jun 2004
    487
    Excellent tip Ray, thanks! If I may say, it's been 4 months since I switched from AutoCAD to Rhino and I haven't looked back.
    JR
    Jun 2003
    20
    Non-Rhino users don't know what they're missing! I was an AutoCAD user too and was constantly frustrated when I tried modeling stuff with a little style. :cheers:
    Shine on,
    RayDOsity
  1. Image (Greyscale) to GCODE
    By rackbox in forum OpenSource Software
    Last Post: 02-13-2013, 12:55 PM
  2. Machining rubber
    By HuFlungDung in forum DNC Problems and Solutions
    Last Post: 05-01-2011, 09:59 PM
  3. High Performance Machining or HSM
    By Scott_bob in forum Polls
    Last Post: 04-27-2006, 08:34 PM
  4. Machining 2219-t4 aluminum
    By scottwally in forum MetalWork Discussion
    Last Post: 06-19-2005, 04:53 AM
  5. Easily trace an image into your CAD
    By Graphcon in forum News Announcements
    Last Post: 11-14-2003, 01:30 PM
