587,543 active members*
6,545 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > X-axis jumps, stepper motor control problems
Results 1 to 2 of 2
    Dec 2010
    Question X-axis jumps, stepper motor control problems
    So I have a CNC that unfortunatly hasn't really worked since I got it and the company isn't any help. I know very little about what actually makes CNC's work so I'm stuck. For some reason when I run a program, the x-axis will "jump" to the left (always the same direction and not always the same distance). I changed the stepper motor controller with a new one from the company I got the CNC from and it wouldn't even move. So they sent me another one and after awhile the x-axis "jumped" again. So I got another new controller and I happened to bend down next to the machine where all of the controllers are located and as soon as I did that, the x-axis "jumped" again. So after some looking into the situation, I believe my cell phone is causing some interference. Could this be possible or is there another issue that would cause the x-axis to "jump" and lose its place? I'm also wondering that if it is a problem with the stepper motor control, can I buy it from someone else then the company I got the CNC from? This company claimed that they are programed differently so I must get one from them. However, I am finding it hard to believe them on anything anymore. I would greatly appreciate any thoughts or ideas on this issue.
    May 2005
    1397
    Loose wire, bad cable.
  1. Cards Support Stepper Motor Driver Control & AC Servo Control.
    By Johnnyatcnc in forum News Announcements
    Last Post: 04-09-2010, 09:57 AM
  2. z axis looses position - like it jumps time
    By jgriffith66 in forum Centroid CNC Control Products
    Last Post: 03-02-2009, 06:23 AM
  3. Mach3 y axis dc servo jumps when moving small increments only.
    By mif73 in forum Mach Software (ArtSoft software)
    Last Post: 09-15-2008, 09:32 AM
  4. Servo motor jumps
    By Alex S.A in forum Servo Motors / Drives
    Last Post: 05-23-2008, 02:28 PM
  5. configuring Mach 3 for twin X axis stepper motor control
    By Alex2005 in forum Mach Software (ArtSoft software)
    Last Post: 03-07-2008, 09:15 AM
