587,636 active members*
3,726 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Interesting 7x12 motor speed controller problem
Results 1 to 15 of 15
    Sep 2007
    13
    I lost the plastic sheeting for the speed controller a long time ago so I had just wrapped the controll box in plastic wrap. I finally decided "bleh thats ugly" and so cut out some plexiglass to protect the electronics.
    When I put it all together I guess a wire shorted to one of the grounds and she wouldnt go.
    Everytime i replaced the fuse it popped instantly.
    I noticed I got a tingle when I touched the heatsinks so I ran a ground wire to the building ground and then when I put a fuse in, she sparked bad again (smoke, one LED turns green and the other is out. The motor runs at full speed (mosfets are blown/shorted)
    If I take out the fuse the second LED momentarily turns green as well then both go out as the fuse is fully removed.
    Im going to replace all the ground cables, the power cable, check the recepticle ground and order a handful of mosfets.
    Is there more of an issue here than a bad ground? I dont wanna resolder 24 mosfets just to learn I should just replace the board and all wiring.
    I have a spare board of same model number (courtsey of my mini mill with broken gears on order) however before I blow that one too what should i be cautious of (other than replacing all ground wires)
    Mar 2007
    2083
    What controller is it
    with more than one heatsink I expect it to be a XTM.... series
    XTM1135
    look here Gerling Laboratories has establi
    if it is you will have 3 diodes and 2 thyristors on 5 heatsinks
    forming a controled bridge rectifier
    is the manual for your lathe available as a free PDF file
    with the extra info i'll be able to suggest some tests
    to do before using the other controller
    John
    Sep 2007
    13
    you are right the 1135 littlemachineshop says its a bad mosfet due to full speed all the time.
    Im going to replace all the grounds and the board and fuse with my mills and buy a new one.
    Mar 2007
    2083
    Don't add any earth / ground wires to the heatsinks
    on the FC250J /230V board in my lathe the heatsink is isolated
    being insulated from the FET's and not connected to the PCB
    but looking at a photo of a XMT series controller it looked like the heatsinks
    are connected to the device they cool no insulating washer being visible
    on the XTM 1135 controller you have a diode on three of the heatsinks and
    a thyristor on the other two
    the thyristor being a type of diode that only conducts when triggered
    to give you the control
    John
    Feb 2010
    +1
    The tab on FETs and other drivers is tied to the center pin of the semiconductor. You can isolate that from the heatsink or let the heatsink "float" as they have. Usually, they isolate the tab from the sink electrically, but not thermally. Little "rubber" mats and plastic washers. If the mats and washers are there, one has failed (usually from over-tightening, usually the washer fails). I probably have some if you need them, just post a pic of the FET and I'll pop a few in an envelop.
    Damn, you're about out of machines, I'm guessing. If you didn't go to metal gears, you might want to order a spare gear or two, if you haven't already. I blew two out in ten minutes one fine day.
    Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
    Sep 2007
    13
    Im saying when I touched the heatsinks after it shorterd/full speed all the time I got zapped.
    I added a ground wire from the regular green grounds to the building grounds and the 'sinks didnt zap me any longer.
    Edit: Wired up the mills power cord, board, and switches etc. to the lathe and it works fine. Im going to try soldering some new mosfets onto the lathes old board and then see if it works. Infact I have an old board that was toast for some reason, maybe Ill try the mosfets off that.
    Mar 2007
    2083
    Hi Nsomnia ,
    looks like I'l have to investigate how you wire things in Canada
    in the UK the domestic single phase supply is one of the phases of a 440V 3 phase supply ( any phase is 240V to earth / neutral)
    the star point of the transformer at the substation is earthed and also connected to the neutral cable
    the incoming mains earth is bonded to any metalwork in the home like the gas mains , water mains and internal plumbing so every thing is at the same potential
    we don't have a separate local earth
    having a look at more photos of XMT... type control boards the heatsinks are not connected to and any of the printed circuit
    while I can not see any insulating washers its possible they have used isolated tab diodes and thyristors ???
    John
    Dec 2003
    24220
    In N.A. domestic supply is a 240v 1 phase center tapped transformer, the center tap is grounded neutral, and is grounded where the service enters the building Only.
    120v to neutral is used for low current circuits, 240v is used for higher current appliances such as Range or Dryer etc.
    I recall In UK, a separate local Earth ground used to be supplied via a Earth leakage trip and ground rod if the ground path back to the grounded star point was not sufficiently low enough resistance, but that was in another life.
    Al.
    Albert E.
    Mar 2007
    2083
    Hi Al
    are yes , the the earth loop impedance test
    I once borrowed the test meter from the sparks at work
    to test the wiring at home
    the worst result was still under 50% of that allowed Im glad to say
    so your mains supply is like the 110V supply used on UK building sites
    ( 110 V centre tap earthed )
    180 degree phase difference between phases that I can understand
    the unbalanced 3 phase that Canada and the US use I have real problems with
    unless I have misunderstood , one version of the 3 phase supply at least
    has a delta wired secondary on the transformer
    the earth and neutral connected to a centre tap on one winding
    back to Nsomnia's wiring
    if connecting the mains earth to the building ( local ?)earth
    stopped the shocks , to me that suggests a wiring problem that needs to be look into
    John
    Sep 2007
    13
    Found out why its fried.
    A trace to one of the mosfets is completly burned out. Im going to try resoldering the trace and replacing the mosfet and see where i get.
    Mar 2007
    2083
    Hi Nsomnia ,
    you can test the speed control on your work bench if you use
    a 20 to 100W GLS bulb ( tungsten not energy saving fluoresent bulbs)
    as a dummy load in place of the motor
    with a low wattage bulb you can test a FC.... type of controller with just one FET fitted
    once you've checked the bridge rectifier and diode across the DC output
    any chance of a photo of the damaged board and FET ?
    in order to see what other components need testing
    John
    ps do you know part numbers on the FET's on your board ??
    Dec 2003
    24220
    The three phase supply here in N.A. is no different from UK, whether Star or delta.
    Just that the domestic supply is single phase source only, consisting of a 240v centre tap secondary, the primary of which is fed from 2 phases of a 3 phase supply.
    When 3 phase only is used the star point is usually grounded or very occasionally one junction of a delta supply is sometimes grounded to obtain a neutral.
    This is usually done at the local level and not a policy of the service supply Co.
    Al.
    Albert E.
    Mar 2007
    2083
    Hi Al ,
    thanks for that , it all makes sence
    some time in the past i've read some info on the web ,
    that was wrong or I've miss read
    John
    Sep 2007
    13
    Found out why it was burnt out. when it shorted, a trace to one of the mosfets burnt right clean off the board. Im going to try resoldering the trace very thin and fine and wire in new mosfets in that position and see if it still works.
    Feb 2010
    You may already know: Usual fix for a burnt trace is to either solder a wire from the pin on one component (ie the FET), then follow the remains of the trace to another component and solder the wire the that pin. Alternately, solder a wire from the FET's pin to the trace itself. If doing the latter, you may need to scrape off the solder mask if there is any. The solder mask is a colored coating, usually green, that covers the board including traces. If there is no mask, it doesn't hurt to scrape it a bit anyway to get to fresh solder on the trace. I use a scalpel or hobby knife with rounded blade.
    That was the 100ish VDC, probably shorted over to the tab on the FET, to the heat sinc, into your finger, and out the bottom of your feet or part of you touching ground. I think high voltage DC gives a nastier bite. I got bit by 400 VDC at my last job, due to an error on the schamatic. That woke me up. Scared the **** out of the lab tech LOL. Got bit by 120 VAC 400 Hz for the same reason in the Navy working on an old A4 Skyhawk. 400 Hz tastes funny. 120 VAC 60 Hz doesn't even bother me anymore. Of course you can still get dead if it goes through your heart. Always be careful and smile while working on circuits, That way if you die, everyone will think you died happy. Makes you mom feel better.
  1. AC brushed motor, speed controller?
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 04-06-2012, 07:30 AM
  2. Motor speed controller?
    By Fastest1 in forum CNC Machine Related Electronics
    Last Post: 10-09-2010, 05:20 PM
  3. 7x12 Motor Controller Problem
    By Nsomnia in forum Mini Lathe
    Last Post: 09-24-2010, 02:52 AM
  4. NEED HELP With Motor Speed controller info?
    By Darian S in forum News Announcements
    Last Post: 07-14-2010, 06:08 AM
  5. Replies: 5
    Last Post: 10-09-2009, 10:10 PM
