587,579 active members*
3,561 visitors online*
Results 1 to 5 of 5
    Jan 2011
    Tornos ENC 162
    I set-up and run an enc 162. I have an alarm code #2018 which reads "motor fault/ spindle variator". I contacted Tornos U.S. and was told they needed the code from the digital readout in the electrical panel in back. It read "AL- 02". I was told that my rpm's were to high for material being turned. I dropped my rpms from 3000 to 1800. it ran fine for about 8 hours. Got the same alarm code, but the electrical panel digital readout is now
    "AL- 06". Can anyone tell me what the AL - 06 means? I reset the machine again and the alarm went off again without the machine even running. Any and all help is appreciated.
    Jan 2009
    30
    Quote Originally Posted by Beep2Beep View Post
    Hi
    The alarm 2018 is indicating there is a fault with the spindle motor or the drive. Check the spindle/motor is not jammed.
    The alarm AL-06 is coming from the spindle motor drive, it's an over speed alarm, it says that the motor speed exceeds 115%.
    However if the alarm is coming without the motor even running, when you power on, it's very likely you have a fault with the spindle motor drive. If that is the case it will need replacment or repair. You need to contact Tornos US for advice.
    Jan 2011
    Need Help! Tornos ENC 162
    I am now getting the code "AL - 22" Can you explain what this one means?
    Jan 2011
    ENC - 162 Spindle Alarm
    I had the same thing happen to my machine. You need to contact Fanuc. Don't bother with Tornos. Roland is good, but even he sent me to Fanuc. I had all the same alarm codes and ended up replacing the spindle control panel in the back of the machine. Here is a link for the alarm codes - Fanuc Alpha axis and spindle alarm codes
    Be advised, the panel wasn't cheap.
    Oct 2011
    Haha did you just post in your own thread from a year ago thinking it was another persons thread?
    Haha
  1. Tornos - Bechler ENC 162
    By Paavan Rastogi in forum CNC Swiss Screw Machines
    Last Post: 12-14-2021, 07:11 PM
  2. Tornos Enc-264 programing help
    By EvansMachine in forum CNC Swiss Screw Machines
    Last Post: 07-08-2018, 01:16 PM
  3. Tornos ENC HELP!!
    Last Post: 09-08-2015, 01:38 PM
  4. Programing Tornos ENC 167 , 163
    By dali_290 in forum CNC Swiss Screw Machines
    Last Post: 11-12-2010, 11:44 PM
  5. TORNOS BECHLER M7
    By CHANDRU in forum CNC Swiss Screw Machines
    Last Post: 06-21-2009, 02:17 PM
