587,865 active members*
3,086 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Proper way to drill ejection pin holes
Results 1 to 11 of 11
    Apr 2006
    235
    I am wondering what is the proper way to drill holes for ejector pins. Textbook calls for +.002" to depth of 3x diameter and then + 1/32" all the way.
    I am using 3/16" ejector pins. Do I drill a smaller diameter hole, then ream, flip the mold over and then drill to +1/32" oversize?
    It's a class project and just drilling with a 3/16 drill seems to work, but I am wondering what is the proper way to do it?
    thanks,
    john
    Dec 2007
    159
    Text book is the way I was taught.Drill,ream,flip and relieve.
    Apr 2006
    235
    thanks,
    I will give that a try. . . though it's tempting to just go with the 3/16 drill . . .
    john
    Nov 2003
    154
    Remember drilling is essentially a roughing operation. You need a good hole for ejection pins. Drilling alone is not a good option. The extra relief behind the pins are so it does not bind or drag for ejection. Allows the ejection plate to 'slide' rather than stick with higher forces.
    15362
    JohnJW
    The text book is not quite right
    You have to drill & ream or bore the ejector pin holes, the .002 clearance in most case's would not work, It depends on what plastic you are going to run in the mold, as to what clearance the ejector pins can have, most are .005/.001 clearance
    You have to check the material spec to see what size Vents they recommend, then you will no from that, how much clearance you can have for the ejector pins
    The clearance around the ejector pin is use as a vent
    To much clearance & the injected plastic will flash down around the ejector pins
    The drill relief in the back of the mold, does not have to be very big, next drill size is more than enough, it's only to give a easier path for the air in the mold to get out quickly 3X dia is ok for that pin size relief, but 3x dia would not be any good for .060 pin
    Mactec54
    Aug 2007
    62
    A word of caution, many small ej pins are stepped, for example a .032 dia pin would have a .125 shank. So the relief for the pin would actually be around
    .156 dia. Not just the next drill size over .032 dia.
    15362
    5axisguy
    That is correct, but in most cases with a .032 pin (anything smaller than .187) you want as small a relief as posible, Only open the large step size were it needs to be done, like in the support plate Etc
    If you releave to much behind a small dia pin, when the part is ejected the pin's bow out into the big clearance , & in a short time they start breaking, have you ever wondered why the small pins break after a short time of use, This is one of the reason's to much pin clearance relief
    Mactec54
    Feb 2011
    17
    for small pin holes, we generally use 1.0 or 1.5mm we just pilot dia 1.0mm all way thro and then wire cut the holes. since doing this 90% of all pin breakages resolved. and i've not had a pin seize up yet. also the pins or the holes do not wear either.
    Mar 2011
    I like to drill from the front,then flip relieve and ream from the back.That way you won't get bellmouthed holes in the cavity area.
    John Stearns
    Hello John:
    I agree 100% with John (brewzz). Ream from the back so you don't bellmouth the hole otherwise you'll get plastic flashing around the ejector pin.
    I was taught to do it this way by my father 40 years ago.
    First create a small hole with a drill spotface counter sink to ensure an accurate location and guide the drill, drill undersize through, flip, drill the clearance hole, then ream through and chamfer the clearance hole diameter in the back. If you don't use a drill spotface counter sink first the drill will wobble until it gets started and your location won't be accurate.
    You'll also get a cleaner hole at the face if you control the speed of the reamer as it exits the steel or aluminum. If you let it pull and lurch through quickly or the hole won't be as clean. A little practice and you'll be a pro!
    Have a terrific weekend!
    Robert
    3D Accuracy
    Feb 2014
    Here is what I have found works when drill and reaming EJ Holes. using High speed tools.
    1) drill size to be 3% smaller than reamer. ie: 1" Ø x 3% = .030 Ø smaller // 1/16 Ø x 3% = .002" smaller. using drill that is close to Ø
    2) spot drill to minimum ream Ø ( if using manual mill, never move table. finish drill ream each hole)
    3) only use new drills.
    4) ream using only coolant. ream at same SFM as drill Ø , but twice the feed rate.
    when reaming difficult materials. a test on scrap is always done
    we went from the manual world to the cnc world. sometimes it takes a little longer to do a good job.
    Gord
  1. Replies: 4
    Last Post: 01-05-2010, 07:27 PM
  2. drill chuck proper use? taper came loose...
    By radioactive in forum MetalWork Discussion
    Last Post: 05-11-2009, 12:38 PM
  3. Trying to drill many #8 holes.
    By ErnieD in forum MetalWork Discussion
    Last Post: 05-10-2008, 06:17 AM
  4. Replies: 6
    Last Post: 12-03-2007, 01:34 AM
  5. Drill holes with end mill or twist drill ?
    By Argofanatic in forum MetalWork Discussion
    Last Post: 12-30-2006, 05:05 AM
