587,300 active members*
3,106 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > What's the difference between "drill rod" and "plated steel rod"?
Results 1 to 6 of 6
    What's the difference between "drill rod," like this: Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies, and "plated steel rod" like the stuff at Lowes?
    Would one be better than the other to use for rails?
    My hobby website: www.roboticsguy.com
    Dec 2006
    108
    Drill rod is high in carbon and is intended to be hardened but it doesn't have to be. It is rated such as W (water), O (oil), and A (air) for how you indend to quench it during the hardening process. It is a littler tough to machine but still does well as it is in it's soft state so to speak.
    The metal at Lowes is most likely a low carbon metal such as 1018 with a protective coating to retard corrison. It can not be hardened and the protective coating would make it a poor candidate for case hardening if necessary.
    Best Regards.
    Carl
    By the way, drill rod is ground so it has closer tolerances than the plated material. So it may be a better choice if you're looking for accuracy even if you don't intend to harden it.
    Apr 2003
    550
    Drill rod will normally be a lot closer to nominal in tolerance..
    Thanks for both your replies! It sounds like I should go with drill rod, since it has higher tolerances.
    How hard would it be to drill holes through drill rod? Would this be possible to do with a drill press?
    Feb 2006
    79
    Drill rod is very easy to machine. Holes are easily drilled through it.
    Aug 2004
    2849
    For rail usage....I would not use either and would instead use Thomson 60 linear race shafting.
  1. mild steel panels needed: 28" x 18" x 0.125" and 13.75 x 23.625 x 14ga
    By torinwalker in forum Employment Opportunity
    Last Post: 01-10-2011, 07:48 PM
  2. Cold-rolled steel plate, 13"x24", 1/2" thick.
    By Odin in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:00 AM
  3. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  4. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  5. 24"X, 18"Y, 3"Z Steel Frame Desktop Machine
    By TLHarrell in forum DIY CNC Router Table Machines
    Last Post: 06-16-2009, 06:33 AM
