587,524 active members*
3,437 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > ShopTask 17-20 XMTC Parts ID Help (W/PICS)
Results 1 to 20 of 20
    Dec 2010
    82
    I have a 1993 Shoptask 17-20 XMTC that had been converted to CNC before I bought it. It came with a box of parts and am trying to decide what they might be for. The parts on the right are probably for the lead screw that had been removed when it was converted. The parts on the left are for "what" I have no idea. Can someone tell me what parts I might be missing should I want to remove the CNC mod and what the other parts might be for? Several pics below for your opinions. Thanks
    THE ONLY PART REMOVED WAS THE LEAD SCREW TO FACILITATE PAINTING. APPEARS THERE IS NO FORWARD/REVERSE MECHANISM TO CONTROL THE LEAD SCREW DIRECTION. HMMMMM!
    Feb 2009
    281
    Quote Originally Posted by LX Kid View Post
    LX,
    It appears that some of the parts have been modified and some fabricated- If someone can help you, it would be easier if you re-shoot your pictures and label each part A, B, C etc.
    Then someone can say A fits on B and so on.
    Dec 2010
    82
    Thanks "Instructor37" for the suggestion. I'll edit my photo's in a short while. Good idea and thanks!
    Dec 2010
    82
    See the edited pics below for ID reference numbers. Thanks
    Jan 2008
    458
    You've got a home-made forward shifter mechanism-
    Start at the lead screw end and work your way up.
    1. On the lead screw you should have a double unit- part of it is a tooth belt pulley for the cnc belt and the other part is a coarse tooth gear.
    2.Shaft A3 should fit into a hole on the casting and is held with a set screw.
    3. Part B2 with the bushing should fit over the spline part of this shaft
    4. The coarse tooth gear marked # 27 should fit on this spine shaft.
    5. The steel pin in part A1 should fit into the end of the double gear unit- you will see that the small gears on A1 will engage the gear on the double unit and can move freely about the diameter.
    5. The gear marked # 27 will now engage either the single gear or the double gear when you move the part A1- this gives you the forward- reverse rotation of the lead screw.
    Not sure if A2 is part of this assembly or not- it may be a shift lever-
    try to assemble the components as I described and shoot a picture.
    Aug 2011
    Thread is a little old but if you are still having any issues figuring out where all this stuff goes’ LMK. I have the exact same machine as you and I have all the gears set up on mine for the auto table movement. Although I may charge you a small fee, I have been having issues with the wiring on my machine... anyway I could get a couple of good pics of the switches and motors on yours.
    Dec 2010
    82
    Found some more parts, that I think go to the 3-In-One, and can't say what they are for either.
    Jan 2008
    458
    D-1,2,3 were all temporary supports for the machine when shipped in the crate- toss them
    C1-6 don't look like anything for the machine-
    Dec 2010
    82
    Thanks SmallBlok. Yesterday I was able to track down the original owner who made the accessory parts for this machine. I sent him this link and asked if he will help ID some of the parts he made. Just have to wait until he gets time to reply. Thanks
  1. Shoptask 1720 XMTC add CNC
    By mustangdug in forum Shopmaster/Shoptask
    Last Post: 11-30-2010, 12:07 AM
  2. Shoptask 1720 XMTC mill spindle runout?
    By Knn in forum Shopmaster/Shoptask
    Last Post: 10-12-2010, 06:50 PM
  3. 17-20 XMTC -?
    By GunPilot in forum Shopmaster/Shoptask
    Last Post: 03-12-2010, 12:16 AM
  4. Shop Task Gunmaster 17-32 XMTC Worth getting?
    By strykerakamack in forum Shopmaster/Shoptask
    Last Post: 01-14-2010, 08:37 AM
  5. Specs for cnc small parts - Shoptask Eldorado
    By pfarber in forum Shopmaster/Shoptask
    Last Post: 12-09-2006, 06:13 PM
