587,787 active members*
6,447 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Adding rigid tapping to VMC15
Results 1 to 9 of 9
    Apr 2011
    Recently bought a used '95 VMC 15, which does not appear to do rigid tapping, and was wondering what is required to upgrade the machine. The machine seems a bit strange, since it does already have a vector drive, encoder on the motor, and all the cabling for rigid tapping. Everything appears to be plugged in as well. When given a rigid tapping command, the machine hangs though. The eproms on the spindle drive card do not list rigid tapping, is this the only thing needed to change to enable this feature? Also the machine does not have a high-low belt system, can rigid tapping run without this?
    Jul 2009
    317
    The Inverter (vector drive) has to have a sticker for Rig tap, also the Spindle controller card Rig tap sticker on Eproms. (3k to 5K $)
    Apr 2011
    The vector drive has a label on it that says rigid tapping, and everything else seems to be in place except for the eprom. It seems strange that the machine would have everything for rigid tapping but the eprom. Did Fadal sell them this way?
    Mar 2010
    rigid tap
    if you have the cable from the drive to the spindle card installed the machine most likly had rigid tapping on it and someone took the eproms.the chips are available at a reaonable price at fadalvmcparts.com or fadalcnc.com.if the spindle card is -5 or older it also needs a rigid tap sticker on it or it will not work,i think someone may have taken the card and the chips on it for another machine.
    Sep 2009
    181
    Give us a call and we'll help you with the parts you need. Most likely what you're missing is the software and/or cable.
    -Shelvin K.
    TheFadalParts.com
    (818) 678-9456
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
    Jul 2009
    317
    Rig Tap, was an option; so we just Prewire some of'm
    Apr 2011
    Turns out we had almost everything to make it work. Just needed newer eproms for the spindle drive card. Rigid tapping works perfectly now.
    Sep 2009
    33
    Where did you purchase the eproms? And how much did you purchase them for?
    Apr 2011
    We purchased the eproms from a seller on Ebay for $300.
  1. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  2. Adding Rigid Tapping to BP Conversion
    By Cartierusm in forum Uncategorised MetalWorking Machines
    Last Post: 08-24-2009, 05:08 AM
  3. Replies: 13
    Last Post: 07-04-2009, 12:43 AM
  4. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  5. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
