587,302 active members*
3,322 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Biesse rover 24 vacuum problem
Results 1 to 5 of 5
    Jun 2011
    Can somebody please help ! I have vacuum on the back cups but nothing on the front ones , on my rover 24 .
    35538
    Sounds like a vacuum line has come off somewhere. You'll need to trace the vacuum lines back until you find the problem. Usually you can hear it leaking if you listen carefully.
    Jun 2011
    I checked and cleaned all the pipes . When I start my machine in winter I have to wait a while before I can use it because all the stops and lifters keep popping up and down . Has that got some thing to do with the vacuum ? What pressure should the gauge be on ?
    35538
    I've never used a Biesse, so can't really help much more.
    My suggestion of the loose line is based on my experience with similar machines.
    As for the stops and lifters, sounds like possibly water in your air lines??
    Jun 2011
    Thanks , I'll check the lines again.
  1. Biesse Rover 335 floppy problem
    By guncha1 in forum Biesse
    Last Post: 10-16-2018, 09:42 PM
  2. Biesse Rover 24
    By lostinbiesse24 in forum Biesse
    Last Post: 12-06-2012, 07:17 AM
  3. biesse rover 20
    By paulhayden in forum Biesse
    Last Post: 11-08-2012, 12:07 AM
  4. Biesse Rover A3.30 problem
    By rliovic in forum WoodWorking Topics
    Last Post: 02-09-2010, 08:33 PM
  5. need help rover biesse 24
    By neon_x in forum CNC Machining Centers
    Last Post: 12-05-2009, 08:22 PM
