588,528 active members*
6,911 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Plasma- Multiple layered AL thin sheet cutting?
Results 1 to 3 of 3
    Feb 2010
    3447
    Could you stack multiple sheets of aluminum together and cnc cut them?
    Sure it works with one sheet, but has anyone tried 2+ ? My guess is, it would weld/melt them together? If not though, it would sure be cool to cut multiple sheets out at one time.
    I had .063" in mind. thanks.
    Jan 2008
    2247
    As long as there is no gap between the sheets they will cut very well stacked up. I worked with a field application where large diameter parts (about 12' diameter) were being produced from 1/8' aluminum sheet. They made a weight that the overhead crane placed on top of a stack of 8 sheets (to hold them tightly together)...they have been successfully cutting these stacked parts for years.
    Jim Colt Hypertherm
    Feb 2010
    3447
    Talking
    Quote Originally Posted by jimcolt View Post
    Jim Colt Hypertherm
    Thats awesome! That would really increase production by "X" amount and save tons of time!! I will have to figure out the weights obviously, but sounds like its doable.
    Thanks JIM
  1. cutting Thin stainless sheet Powermax 45
    By adscnc in forum Hypertherm Plasma
    Last Post: 10-27-2010, 11:44 AM
  2. Plasma cutting copper sheet
    By JerseyBill in forum Hypertherm Plasma
    Last Post: 05-25-2010, 07:03 PM
  3. Need help holding and cutting thin Al sheet on router
    By glenneaux in forum Uncategorised MetalWorking Machines
    Last Post: 09-01-2009, 12:43 AM
  4. HELP! CUtting sheet metal with plasma
    By Sam4691 in forum MetalWork Discussion
    Last Post: 07-14-2009, 12:40 AM
  5. RFQ - Cutting Thin Plastic Sheet
    By ukchris in forum Employment Opportunity
    Last Post: 12-07-2006, 03:16 AM
