587,758 active members*
2,746 visitors online*
Results 1 to 7 of 7
    Feb 2012
    Designing a cnc router
    im new here, ive been looking into building a cnc router after see'ing what people have made on the internet.
    Im currently a cnc operator for a steel engineering company, but i just want to use a this build for wood.
    im going to design it using autocad/inventor or alibre, which ever im using most of at the time then hopefully build it this year, well thats the plan.
    ive got few ideas and equipment to start with, unsure whether to build a small one just for A4 sized wood/engraving or A3, preferably A3.
    but before i start, im unsure whether the frame work im thinking of will be strong enough, so would appreciate some advice please.
    i have have 40 x 40 bosch extrusion framework to use, and was hoping to use it for the whole frame, would this be strong enough?
    i thought of doubling it up but then wondered if it would start effecting the precision of the machine when having to drill the holes for the bolts or adding plates to keep them together as the may be slightly out when assembling.
    any advice is much appreciated, ill no doubt have more questions later, but this will get me started
    Mar 2009
    533
    Try looking at what other's have done. e.g. Joe's Hybrid 4x4 CNC Router
    You can find him on this forum too.
    Sep 2010
    717
    Quote Originally Posted by prodigy86 View Post
    40 x 40 Bosch? Item uses 40 x 40, bosch has 45 x 45 last I checked. Anyway, it's rigid enough for cutting wood especially if it's small(ish) like A3.
    The "weak link" will be the connecting elements, get rigid ones. Not those small (Bosch) corner connecting things with a set screw..
    Not to mention good linear slides etc etc
    Hub
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
    Feb 2012
    pretty impressive that of joes hybrid, would love to achieve something like that, mabye in time
    i think its bosch, not too sure, just what was told, its 40x40 with the tapered t slots in, seems strong stuff.
    will have look about for connection parts, see whats about, hopefully linear slides i got are ok. cheers
    Apr 2009
    5516
    Quote Originally Posted by hub View Post
    Hub
    Bosch Rexroth definitely has 4040 extrusion; in fact they have 20, 30, 40, 45, 50, 60, 80, 90, and 100 series extrusions. It is their regular-duty extrusion, theoy don't make a heavy-duty version in 4040.
    Bosch has many gussets and connectors, as well as a variety of t-nuts with metric and Imperial threads. You can order direct from their werbsite, and it's shipped from your closest distributor...
    Sep 2010
    717
    Quote Originally Posted by louieatienza View Post
    Yes you are right, I checked their catalog. I just never saw it before for some reason.. I have only used 20 & 45 base profiles. All the 40x40 profiles I have used are made by Item. They are "heavy duty" product No.: 0.0.026.03.
    Aug 2022
    11
    Re: Designing a cnc router
  1. Need help designing 2' x 6' router for ski/snowboard construction
    By Rswilliams13 in forum DIY CNC Router Table Machines
    Last Post: 10-18-2011, 11:00 PM
  2. Designing a CNC
    By tequilaguru in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-16-2007, 10:24 PM
  3. Designing/planning my first cnc router
    By capncrunch in forum CNC Wood Router Project Log
    Last Post: 09-21-2005, 05:48 PM
  4. Designing a Powerful Router
    By atemylunch in forum DIY CNC Router Table Machines
    Last Post: 03-25-2005, 04:45 AM
  5. designing my first CNC
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 07-01-2003, 10:40 PM
