588,385 active members*
5,203 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Hot-Wire option for foam cutting - anyone have ideas about this?
Results 1 to 10 of 10
    Feb 2012
    Lightbulb Hot-Wire option for foam cutting - anyone have ideas about this?
    i recently built a desktop cnc router, mainly for cutting small parts:
    thread-> http://www.cnczone.com/forums/diy-cn...nc_router.html
    now being an architecture student it would be nice to have a Hot-Wire cutting option for cutting small parts of foam that then could be used for making study-scale-models.
    i now have a hand cutter like this:
    and this is a quick sketch of how i can combine this with my cnc:
    -> keep in mind i don't want to use the existing hand-cutter because it is not made that strong, it would have to be a new design...
    now my question was how you guys should make this?
    i don't find many info about this way of doing it.
    i only find cnc machines that are made for hot-wire cutting only but not how to make a hot-wire "option' on an existing cnc machine.
    also, how would you guys connect the hot-wire itself if the u-shaped bar is made of aluminium? needs some sort of insulation between the hot-wire and the bars.... ?
    thanks in advance for your ideas!!
    Feb 2008
    231
    Since you have already built your CNC router you have conquered 9/10ths of what it takes to understand and construct and operate a CNC foam cutting machine. I have also concluded that it would be nice to have a CNC hot wire machine and have considered making it an attachment for my router, but the reality is that it would be better just to build a CNC hot wire machine dedicated for just that purpose. They can be made for much lower cost than a rigid CNC router and they can be taken down and put away in a small space when not in use.
    Hot Wire Foam cutting CNC Machines
    Feb 2012
    Quote Originally Posted by ssutton View Post
    thanks for the link!
    but at the moment i don't have the budget to make a 'new' cnc machine for foam cutting only, even if it's cheaper.
    and i think my ambition in foam cutting is not that large to make a fully new machine. i will only use it for small pieces, therefore the 'option' to put on my existing machine.
    Jan 2008
    853
    This is interesting, but I have more questions than help; sorry!
    What size of foam (x,y,z) are you thinking of working with? It seems like everything depends on this.
    Will you always start at the outside edges, or do you make a hole and insert the wire like a coping/scroll saw?
    Do you need a dynamic tensioner (spring?) to keep the wire taut as it heats and expands? Some flex in the wire support may be a good thing.
    The need for a 'foot' under the work (if the wire is vertical) makes this look more like a CNC embroidery machine than router.
    Feb 2012
    Quote Originally Posted by PaulRowntree View Post
    1. the thickness of the foam would be max 5-6cm (i have 9cm of space under the z-axis).
    and the x/y dimensions of my router are 20x40cm at the moment so the max size of the fom would not have to exceed this.
    2. for me it's no roblem to always have to start at the outer edges of the foam.
    3. i could use a dynamic tensioner but is not necessary. i have a foam cutter and it uses the u-shape to tension the wire. but i will concider using a spring.
    4. and if the cnc machine looks like an embroidery machine it wil only be when the foam cutting option is mounted so i dont see anything wrong with that
    Jan 2008
    853
    Ok, so more questions ...
    What do you do when the piece gets cut free? The work has to be floating above the table (for the foot) so does the released piece just rattle around?
    Khalid's thread on embroidery machines makes for a good read; these machines have their own hardware and software issues that are quite interesting nuts to crack.
  1. Replies: 1
    Last Post: 11-06-2012, 05:09 AM
  2. Hot wire foam cutting with EMC
    By linuxstep1 in forum LinuxCNC (formerly EMC2)
    Last Post: 05-05-2012, 01:28 PM
  3. Mechanical ideas for a CNC foam cutter
    By Spiral_72 in forum CNC Wire Foam Cutter Machines
    Last Post: 07-13-2009, 11:19 PM
  4. Wire for foam Cutting "EdgeSweets" machine
    By singerdon49 in forum Employment Opportunity
    Last Post: 12-29-2008, 03:12 PM
  5. help: Foam cutting CNC construction ideas
    By KC8QVO in forum CNC Wire Foam Cutter Machines
    Last Post: 02-14-2006, 05:23 AM
