587,735 active members*
2,838 visitors online*
    Sep 2011
    Deckel Maho dmc63v
    I have problem with magazin liste and tool liste.
    For example: In pot 1 is toll number 500200.
    In pot 2 is tool number 300500 and so on.
    I can't change the name of tool, and load and unload tool from magazine to tool list. It is not alowed.
    I copy tooI and magazin data on diskette and change it manualy.
    pot 1 is tool number 1
    pot 2 is tool number 2 and so on.
    But this is a temporary solution. Maschine has Simens Sinumerik control 810d from 2002 year.
    If someone knows something please help.
    Thanks!
    Apr 2002
    5003
    I change the toolparametres only in the toollist. Eventually you could ask siemens @ DOConWEB You can download nearly all availible documentation for the control.
    Sep 2011
    Quote Originally Posted by uli12us View Post
    Which parameter did you change??
    Apr 2002
    5003
    There are only 2 meaningful Parametres, Tool radius and length. The Toolsort should always be 120. At my machine the toollife don't work.
    The only disadvantage of this is, that you can only use Toolnumbers from 1 to 24. If you have hundreds of toolholder which have always the same tool in it, the magazinelist is better than that. But if you use the tools only for the actual part and change it for the next part, than the toolist is better.
    As I got the new machine, I tried to use the magazinelist like discribed in the books, but this was extremely complicated. Now I change all tools first only with the Axisbutton and the turnswitch. After that I take each tool in the spindle and change the lengthdifference to the tool before, and the new radius.
  1. Deckel Maho FP3- new project
    By keven88 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-05-2023, 09:50 AM
  2. deckel maho dmu 50 t
    By gunz in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-24-2021, 01:54 PM
  3. Deckel Maho DMU 50 VL
    By waltteris in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-13-2016, 09:32 PM
  4. Deckel Maho 63V Post
    By louorfran in forum Surfcam
    Last Post: 04-14-2014, 04:21 PM
  5. VERTICAL DMG DECKEL MAHO
    By CNCCS in forum Vertical Mill, Lathe Project Log
    Last Post: 04-17-2008, 09:24 PM
