588,268 active members*
10,102 visitors online*
Results 1 to 12 of 12
    Nov 2007
    9
    Machine Monitoring "advanced"
    We are currently using eNetDNC to upload/download programs, which works great. But we are also attempting to use it for machine monitoring/data collection, which is turning out not so great. We have the eMonitor boards that are hard wired into cycle on/off. We have alot of cycle on/off signals being captured, due to the way the machines are being ran. We are not a high production shop that produces many parts within a shift. Also, we tend to start and stop, sometimes even startover our programs in certain areas to accomplish the machining of a large casting, this is where most of the cycle on/off is coming from.
    The problem we are seeing is that cycle off may not mean that the machine is down, as in nonproduction, the operator may be checking the cut, checking tooling, measuring, etc.
    We have tested the DPRNT function to try and capture some of this activity, but since we bounce around in the program so much, the DPRNT lines may not be "read". Also, it seems that the only thing that terminates a "cycle on" condition is a "cycle off" condition, according to eNetDNC. So event definitions are worthless using DPRNT if cycle off occurs before the DPRNT line, and if you switch, then the event definition does not terminate the cycle on condition.
    Has anyone ever had these types of conditions to deal with?
    I was thinking about supplementing eNetDNC by doing something in the machine ladder, or adding an additional small plc to create some intelligence to capture certain conditions. I was thinking maybe some "If........THEN......." statements or something to capture more conditions, then output them to the eMonitor board.
    Maybe capturing "single block signal" and "spindle on" in a IF THEN statement to keep a "cycle on" condition true just for the eMonitor board input?
    I think everything would be great if we ran parts back to back, running through programs nonstop, but we don't.
    Any help on this would be greatly appreciated!
    May 2004
    4519
    I would think all you need is to capture the time of M30 (program end). Then match that with actual part count.
    Then fire a couple of people and I bet your production numbers go up.
    Feb 2009
    6028
    Ive done it, but on only Mori's.
    MORI SEIKI GLOBAL WEB SITE | PRODUCTS | Network
    Nov 2007
    9
    variety of controls
    We've got a variety of controls that we're dealing with. We've got Mazak, Fanuc, Siemens, maybe some others. The main one I'm concentrating on right now is a Fanuc 15TA, basically for test purposes. This is the oldest of them all, so if we can do something with this one, the rest may be easier.
    I'll have to look into the M30 idea, but we may not finish a part in one shift, if that matters with M30.
    I need some more brainstorming here.
    Aug 2009
    684
    We have a similar scenario, so I added custom G codes at start and end of pgm to ensure that part was only counted once, and a G code at end of each sequence to check for rework. It does require strict program format to do it this way though...
    DP
    Nov 2007
    9
    Quote Originally Posted by christinandavid View Post
    DP
    Can you send me an example of this? or post it?
    May 2004
    97
    Quote Originally Posted by themetalbarn View Post
    What controls do you have? We can monitor some Siemens, Mazaks and Fanucs through the Ethernet port and give a load of information that is unambiguous including Feed Rates turned down etc.. It does depend on age. My advice for the older controls, accept the limitations - you will spend a lot of time and effort and frustration trying to eek out every signal from them. DPRNT & data acquisition modules work but can be time consuming to add. If your Mazaks are Fusion / Matrix, your Siemens is 840D (PCU50) and your Fanuc an i Series with FOCAS we just install some software, plug in a cable and away you go... no major program changes or signal finding required.
    Aug 2014
    4
    Re: Machine Monitoring "advanced"
    Anything you can share about how to get monitoring data from the Mazak Fusion / Matrix controllers? I'm interested in writing my own monitoring software.
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
  4. First Machine HELP...24"x36"x4" or Larger Setup w/ Gecko for under $3000
    By buschhoff in forum Want To Buy...Need help!
    Last Post: 03-21-2010, 12:37 AM
