Thanks Herby,
The brake down was very interesting. I'm not sure I'd do all at once, I'll most likely space things out as much as it is possible to do. Iv been looking at dsp controllers, but to be honest I'd like to give the native drivers a go first, just to see if I can get anything constructive out of it.
Iv also found a Chinese page regarding the laserDRW and WinsealXP drivers:
Google Translate
It looks like the presumption that these new titles are USB newly clones.
My main question now is:
Out of the 3 types of driven machines, which would you recommend?
Newly comparable (parallel)
Moshi (USB)
LaserDRW & WinsealXP (USB)
I like the idea of USB, not only for the obvious reasons but I also thought that a hub could be fitted in the electronic compartment so the dongle could be internally fitted. But then again the parallel could be converted to USB and could provide Mach communication.
The other thing ive noticed on the page posted above is that all the boards have crystals wired onto the board, so in therory the speed of cutting could be slowed. Iv seen this done on YouTube, but could it be made to cut faster? Also, on the board marked WinsealXP, there are two crystals, one for cutting? One for engraving? Finally the dates on the boards show that the WinsealXP/laserDRW were printed in 2010/11 so are older than the more upto date Mushi boards.
Again, any recommendations would be much appreciated.
Thanks, Steve.
