587,534 active members*
3,512 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Rotary Indexing Not posting correctly.
Results 1 to 2 of 2
    Jan 2009
    245
    Ok, so I have this block, and in the block is a through hole off center. I am drilling and boring from each end with rotating 180deg for indexing. I set WCS at top. C and T planes are at bottom for the indexing tool path. I then look at the post with 4th axis and rotary axis positioning about x axis turned on. This is what it does.
    G20
    N102 G0 G17 G40 G49 G80 G90
    N104 T4 M6
    N106 G0 G90 G54 X-.0115 Y.0861 A0. S1800 M3
    N108 G43 H4 Z6.
    N110 Z3.63
    N112 G1 Z-.065 F2.
    N114 X.0115 F5.
    N116 G3 X.664 Y.75 R.664
    N118 G1 X-.664
    N120 G2 X-.0115 Y1.4139 R.664
    N122 G1 X.0115
    N124 Z.035 F25.
    N126 G0 Z.25
    N128 Z3.63
    N130 A180.
    N132 X-.674 Y.75
    N134 G1 Z-.065 F2.
    N136 G3 X.674 R.674 F5.
    N138 X-.674 R.674
    N140 G1 Z.035 F25.
    N142 G0 Z6.
    N144 M5
    N146 G91 G28 Z0.
    N148 G28 X0. Y0. A0.
    N150 M30
    Can someone advise why its doing a 180 in the middle of the program?
    Attached Files Attached Files
    Dec 2008
    3127
    The A180. is the NC rotary command to move the 4th axis to enable machining the hole from the opposite side. You did also notice the A0. on line N106 ?
    Query ????
    Did you use the system BOTTOM view ??
    This IS NOT a correct view that a vertical machine ( with the 4 axis around X) is capable of. You will find that the NC code is 180° ( around Z ) out of position.
    You have to avoid using the BACK & BOTTOM ( system views ) & create the correct ones yourself.
    PS
    You have sometimg strange going on, the top contour is doing a R0.664, but on the bottom, it is R0.674--- you have either different XY offset values, or the contours you have selected are different rads.......then again it may be intentional
  1. problem posting MCX5 posting to Cimco edit v5.6
    By cdmmachining in forum Mastercam
    Last Post: 05-10-2012, 02:09 PM
  2. Rotary/indexing questions....
    By prtmkr2010 in forum GibbsCAM
    Last Post: 06-22-2011, 07:57 PM
  3. 4th axis positioning is not posting correctly.
    By TXFred in forum Mastercam
    Last Post: 06-10-2010, 02:06 PM
  4. 12" rotary table Indexing parts needed.
    By srmaietta in forum Bridgeport / Hardinge Mills
    Last Post: 06-08-2009, 05:49 PM
  5. rotary indexing mcx2
    By daisydog in forum Mastercam
    Last Post: 09-17-2007, 11:02 AM
