587,656 active members*
8,233 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Bobcad V24 & Camsoft & arcs
Results 1 to 17 of 17
    Oct 2003
    128
    I am having a heck of a time with V24, my Camsoft control and G2, G3. I have a request in for a post but my customer is screaming as I am way late on this job. Maybe I can get this solved with some help here. I do have this posted over in the Camsoft forum also.
    The last program I did with Bobcad for this machine was in V19 and it worked at that time.
    At certain parts of the program the tool will make an unintended 180 deg arc or complete circle.
    I have tried the 3 settings in Camsoft for the Fanuc arcs along with the corresponding changes in the post with no success.
    Marc
    Mar 2012
    1570
    Breaking up arc movements.
    221. Break arcs into quadrants? y
    223. Break arcs into two pieces if greater than 180 degrees? y
    By setting both these blocks in your post to yes it will post arc movements at every 90 So if you had a full arc 0-360 it would be posted in 4 blocks of code.
    This should resolve the issue you are having with the camsoft controller and reading arc movements.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Oct 2003
    128
    Al, I just tried that. Here are my settings
    Camsoft - fanuc arcs = 1 (incremental)
    222. Arc center a=absolute, b=incremental, d=unsigned inc., e=radius? b
    No joy
    Marc
    Mar 2012
    1570
    Ok,
    Are you cutting a simple shape or is it a complex curve?
    What is the name of the post you are using and where did you get it?
    What other options does camsoft have for your arc settings?
    Al DePoalo
    Oct 2003
    128
    It is an engraving job, lots and lots of little moves.
    Camsoft does not have anything else I can think of for arcs, just absolute, incremental or R value.
    This pic is from an earlier test, now it is making little circles.
    Marc
    Apr 2009
    3376
    Yeah,this happens.The only way I have found to deal with this is to Back Plot the engraving and where it screws up,zoom in and Explode the area in question.The downside is your going to have a lot of little segments where you Explode.That works for me.Also make sure all of Engraving is on same plane.That can also give undesired results.Also make sure you do not have any double entity's.Run the Re-Organize under Utilities.And I might add,do not explode more than you need to.A totally Exploded Engraving will look not so good either.
    Mar 2012
    1570
    It's bad geometry... What's bad geometry? Well there are lots of answer for that, but the one you care about right now is you have very tiny little line and arc segments that make up your 2D engraving geometry. My guess is you used corell draw to do the vectorization.
    Anyway, you need to clean up the geometry to make things work right.
    1) when you select the geometry to engrave does it chain select?
    2) Have you tried using
    Utilities>Reorganize > Cleanup and optimize
    I may be wrong but my money is on it being a geometry issue. If you can clean up or simply your geometry the problem will go away.
    You are dealing with a short arc tolerance, where the arc segment starts and finishes in such a small amount the controller reads it at as a full arc.
    So clean up or simply your arcs ( making them larger pieces of arcs vs small little tiny ones )
    or
    Convert all you arcs into line segments.
    Using Utilities > Explode > Arcs
    This will break all your arcs into line segments. This way you do not need to worry about the arcs at all because you'll be cutting line segments.
    Anyway I hope this information helps you.
    Al DePoalo
    Apr 2009
    3376
    If you still are having problems after the suggestions above,zip a .bbcd file of your engraving on the forum and I or somebody can take a look.Unfortunately I have dealt with this alot before.And not always BoBs fault.Al is right,usually a geometry issue.This happens in engraving,even BoBCADs book of 6000 cliparts,there are issues with them.
    Jun 2008
    1838
    Crop circles !!!
    mbam
    "Crop Circles", so called because no one knows where they come from
    I have had this happen to me on a numerous occasions over the years with both BobCAD-CAM and other much more expensive softwares and apart from what has already been suggested here is what I have found is usually the problem.
    It happens when the tool is asked to go to a specific coordinate by way of an arc but according to the geometry the arc is either too small or the tool is too big and won`t fit through what the software "sees" as the gap the tool should go through and it obeys the command to get to the point by going "the long way round" for want of a better expression.
    I`ve usually just changed the tool diameter on most but on the odd occasion where that wasn`t a viable option I have very slightly altered the geometry to in effect "allow the tool to pass"
    Quite often a look at the "stepover" amount and reducing that will clear it as well and that is the easiest/best option
    So far I`ve not had to use any other method to rectify this issue, worth a try
    Regards
    Jun 2004
    42
    Crop cir.
    Change line 222 from b to E for radius don't use small e for radius. If you still get crop circles change line 221 & 223 small y's to captial Y's. I don't why today I was setting up my post for ver 25 and it would not work until I changed to a big E. I then checked my post on version 23 and it was a big E.
    May be worth a try.
    Toolbit
    Oct 2003
    128
    Well, here is what I have found. I used some of the utilties in Corel Draw to clean up the logo, then saved it as a PDF. Then imported the PDF into Bobcad, cleaned and optimized.
    I then created 2 programs using the respective posts, one for my Fadal with a CNC88 and one for the Camsoft.
    The Fadal runs it fine, same issues with the Camsoft. I'm going to compare them line by line. They should be essentialy the same, yes?
    I know, why don't I just used the Fadal? The material is really too big to fit the machine without taking the ends panels off, even though it looks like I will do that. And I just spent a week mounting a 24,000 RPM spindle on my Bridgeport so I could do this job.
    Marc
    Oct 2003
    128
    Also, 1) when you select the geometry to engrave does it chain select?
    Yes -it does now, it did not before.
    Marc
    Mar 2012
    1570
    I though you were working with corell.... It's a great program for converting images, it does a really accurate job of it. The down side is that geometry created has lots of segments and most overlap or are not connected. It's the trade off you have for getting a very accurate representation of your image. Because you are engraving and the part looks small converting the arc segments over to lines I do not think will compromise how the engraving looks...
    At this point have you been able to cut the part correctly?
    Al DePoalo
    Oct 2003
    128
    Al, I still cannot cut the part with the Camsoft machine.
    I am going to try exploding the arcs next.
    I guess I will have to figure a way to get the workpiece in my Fadal if that does not work.
    Marc
    Mar 2012
    1570
    work case send me the file and I'll fix it for you so it works....
    Al DePoalo
    Mar 2012
    1570
    Ok I've sent the file back. All I did was explode the arcs to line segments. It will be a longer program but you will not have any arc movements therefore you won't have any issue with the "crop circles "
    Al DePoalo
    Oct 2003
    128
    Turns out this was a problem with Camsoft. There was something fubar in the configuration file. After redoing the config all versions of the file from Bobcad now run fine.
    Thanks for helping me figure this out!
    Marc
  1. Camsoft & Bobcad - problem with arcs
    By mbam in forum CamSoft Products
    Last Post: 08-26-2015, 07:19 PM
  2. Camsoft and Bobcad ???
    By nelZ in forum CamSoft Products
    Last Post: 01-21-2011, 04:39 PM
  3. Incremental arcs and Break arcs into lines
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 09-16-2010, 04:55 PM
  4. I and J 3D arcs
    By mmachining in forum BobCad-Cam
    Last Post: 02-14-2008, 08:01 PM
