587,999 active members*
2,300 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Breaking taps on retract (Lancer 1500)
    Aug 2012
    Question Breaking taps on retract (Lancer 1500)
    Hello everybody,
    The company I work for recently bought a used Cincinnati Lancer 1500 with the Acramatic 2100 controller. They tried tapping with it last week and everything went fine till it came time for the retract. The Z axis is wanting to travel faster then it did on the plunge and breaks the tap. The operator thinks it is in the post but I don't have any idea where/what to look at. It is a generic post that i made a few simple changes to on the "pheader". Any one have any ideas on what I need to look at or if it might be a parameter in the controller? Thanks.
    Ps: We use MasterCam V9.
    Mar 2011
    465
    Assuming you are using Rigid Tapping, retracting faster should not be a problem if everything is set up correctly, this is commonly used to speed up tapping cycles.
    If you are concerned the MasterCam post is at fault, I'd start by just writing a tapping cycle at the machine and see if it works without anything from Mastercam. If you have the same issues, it obviously isn't anything in your post causing the issue.
    May 2005
    2502
    Even with rigid tapping, you can get better tool life with a tension compression holder:
    CNC Rigid Tapping
    In your case, that may be the easiest fix, assuming you don't track it down to a post problem.
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Aug 2012
    The operator is going to try manually inputting a drill and tap cycle. He said he would let me know how it goes. Thanks for the replies.
  1. Breaking 0-80 Taps.....
    By nfrees114 in forum MetalWork Discussion
    Last Post: 12-01-2010, 05:46 PM
  2. breaking taps!!!!!
    By dieman1968 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-01-2009, 10:06 PM
  3. Breaking Taps?
    By tricmachine in forum MetalWork Discussion
    Last Post: 01-13-2009, 08:22 PM
  4. Breaking 6-32 taps
    By CNCMike in forum MetalWork Discussion
    Last Post: 12-05-2008, 10:27 PM
  5. TAPS BREAKING !!
    By weaston in forum MetalWork Discussion
    Last Post: 07-07-2008, 08:08 PM
