603,796 active members*
3,993 visitors online*
Results 1 to 5 of 5
    Sep 2012
    connection problem
    Multi Cam 103 was working but now we get the following error when we try to connect.
    Another application
    Connection established: MultiCam MG103 (5976)
    Project file: c:\DncFiles\Multicam2.etc
    WorkSpace: Default
    Attempting to connect to MultiCam MG103 (5976)...
    WorkSpace: Default
    [08September2012 16:40:33] ETCComX.ocx 3.9.29.0
    The attempt to connect was forcefully rejected.
    MainPort Connect()
    [08September2012 16:40:37] ETCComX.ocx 3.9.29.0
    10061 - The attempt to connect was forcefully rejected.
    MainPort Connect()
    No connection could be made because the target machine actively refused it.
    Another application at IP address is currently using the connection to this Machine Tool.
    [08September2012 16:40:37] JobServer.exe 3.9.36.0
    ...JobServer is currently OffLine
    WorkSpace: Default
    at IP address is currently using the connection to this Machine Tool . We can unplug , turn on and off and get it to work eventually but its a pain. Any ideas?
    Jun 2010
    480
    connection problem
    Are you using a static IP address for your machine and PC?
    Sep 2012
    Yes. Both are static.
    Jun 2010
    480
    Connection problem
    Is this machine connected to a network or is this machine only connected:
    Machine-Ethernet Switch-computer
    Or
    Are you connected machine-computer
    Nov 2011
    4
    I had a similar problem, the multicam IP address will not show up on a network in some cases. The IT department issued the same IP address on another device and it would not let the router connect.
  1. X4 connection problem
    By Edwinrist in forum Syil Products
    Last Post: 07-12-2012, 09:15 AM
  2. connection problem
    By snob in forum Fanuc
    Last Post: 10-07-2011, 07:30 PM
  3. Connection problem
    By wsx in forum DNC Problems and Solutions
    Last Post: 03-31-2011, 09:18 PM
  4. Pc to num connection problem
    By iscal in forum DNC Problems and Solutions
    Last Post: 03-18-2010, 01:52 PM
