587,207 active members*
2,901 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Spindle start and stop and tool change
Results 1 to 2 of 2
    Sep 2012
    I am using the generic router post processor. When my g code generates there is no "s" value for speed so the spindle will turn on when I first start the program but when it gets to the first tool change it goes to home and without hitting cycle start again the program will carry on and not re-start the spindle. I can go in and manually write the lines, but is there a way the bobcad can generate the correct code? BTW I am using a mini maxpath with a modified mach 3 controler that came with the machine.
    Jun 2008
    1838
    Quote Originally Posted by inman20k View Post
    Open your Post Processor in Notepad and go to line 3 which is the toolchange coding, there should be a line like this:-
    n,s,spindle_on
    This will call up the spindle speed and turn the spindle on, if it isn`t there then insert it immediately after the line:-
    n_forced,t,"M06"
    Regards
  1. vfd spindle start/stop problem
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 12-14-2010, 05:49 AM
  2. Start/Stop spindle noise
    By mathieu in forum Haas Mills
    Last Post: 08-13-2009, 01:43 AM
  3. Spindle stop prior to tool change?
    By nitemare in forum Mori Seiki Mills
    Last Post: 04-21-2009, 12:37 PM
  4. G-Code to start and Stop Spindle/Router
    By planekrazie in forum G-Code Programing
    Last Post: 02-09-2009, 03:54 PM
  5. spindle start/stop through VFD
    Last Post: 01-09-2009, 04:47 PM
