588,495 active members*
5,114 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > How to calibrate tool probe?
    Jul 2009
    86
    Exclamation How to calibrate tool probe?
    Hello,
    I am wondering if anyone here is familiar with calibrating the tool probe on a Doosan lathe?
    The machine is a Doosan Lynx 220L equiped with the Q setter.
    After probing tools the machine cuts approx .016" different than it is commanded to. I have re-calibrated the tool probe on HAAS lathes many times but can not seem to figure out which parameters or settings to change on the Lynx to correct this error.
    When the machine was new everything cut fine within .0005" after probing, so the arm has ovbiously been bumped.
    A walk through would be greatly appreciated.
    Thanks,
    Colton.
    Nov 2007
    188
    tool probe calibrating
    Check out the post below it should help you
    http://www.cnczone.com/forums/daewoo...djustment.html
    Feb 2010
    10
    What control is fitted to the machine?
    Jul 2009
    86
    I am not 100% sure on the control but the instructions I found and had success with says that it is for machines with the following controls:
    FANUC 16T, 18T, 21T, or 0-i
    Everything ended up working, here is a list of the parameters where the adjustments were made:
    X O.D. contact - parameter 5016
    X I.D. contact - parameter 5015
    Z right side contact - parameter 5018
    Z left side contact - parameter 5017
  1. Tool Probe
    By reedmiles in forum Haas Mills
    Last Post: 08-31-2010, 05:42 PM
  2. Renishaw tool offset / break probe and tool life management
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2010, 04:14 AM
  3. calibrate tool eye
    By zed in forum Daewoo/Doosan
    Last Post: 09-25-2007, 04:17 PM
  4. How to calibrate Tool Eye
    By mudbug in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-01-2007, 01:14 AM
  5. Tool Probe Arm
    By phoodieman in forum Daewoo/Doosan
    Last Post: 11-01-2006, 10:32 PM
