587,541 active members*
7,207 visitors online*
Results 1 to 13 of 13
    Jan 2007
    723
    Where to get a laser height focuser?
    I've been doing some looking around for a laser focuser for my retrofit. I haven't seen any info on them or where to buy them. Can anybody clue me in as to what they are, how they work and where to purchase one or at least where to get the parts to make one?
    I'm using the lightobject Dsp Awc-608 and I would like to automate the height of my z table.
    Thanks!
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Sep 2011
    296
    Quote Originally Posted by Pplug View Post
    Thanks!
    Hi, It is something like this one. It works to keep a fixed focial length. Here is a video to show how that works.
    [ame=http://www.youtube.com/watch?v=7xwz-ADo-lo]Auto focus of laser - YouTube[/ame]
    Melody
    Sales Manager of G.Weike
    E-mail: [email protected] [email protected]
    Skype: melody.gweike
    Jan 2007
    723
    I was looking for something that does not make contact with the material. If I used that touch sensor on a piece do paper on my honeycomb cutting table, it could go throught the material.
    Thank you.
    Jul 2012
    WK has a version that does not make contact with the material, basically you place the included block of aluminum under the sensor, and once it gets close enough (never actually making contact) it will stop moving the z axis. It works great and is very accurate. Unfortunately, on some machines, the z axis is driven by a single motor, and sometimes the table binds up as the motor tries to move too quickly. The fix is pretty simple: slow the motor down.
    With a proximity-sensor just beside the lens-shaft and a certain block of metal (for each focal length anothe block) this auto-focus thing is a piece of cake.
    Just move the tabel down sofar that the block can be placed on top of the material and under the sensor. select autofocus and enter.. the table moves up till the sensor is activated. now take away the block and your ready to go.
    I will make a little film soon how to replace the lens and adjust the sensor in a minute or so..
    Kees
    Attached Files Attached Files
    Jan 2007
    723
    Very nice! This is exactly what I was looking for! Now I have to see if it will work with the awc-608 dsp controller.
    I'm quite sure it will work with that controller. connect to Z+ of U/Z limit (pin 5)
    for more info, just request
    Kees
    another view on the proxy:
    Jan 2007
    723
    Great! Now, where do I get one?
    This has been some excellent help! Thank you!!
    You can buy them on ebay for just a couple of dollars. There are plenty of them but what should you look for?:
    A smaller sensor is lighter, so a 8mm diameter is preferred (mine's 12mm)
    the detection distance should be as small as possible: the reproductive measured distance is a percentage of that detection distance.. try to get 2 or 1.5mm
    The output should be NPN type. When the sensor is activated this output is drawn to GND
    There are two types: Flush and Non-Flush. I prefer Flush types as they only "look" in front of them (With non-flush types you see the plastic part coming out of the metal shield)
    Find a type DC6-3xV, Although this should work from 6 to 30-somwhat Volts it works fine at 5 Volts too.
    The right proximity sensor has three wires: Brown (+), Black (output) and Blue (-)
    I think this one is nice but there are many others..
    LJ8A3 2 Z BX 2mm Inductive Proximity Sensor Switch DC 3 Wire 6 36V NPN No | eBay
    Here a little film i made How i change the lens and at the end the whole autofocus procedure..
    http://youtu.be/EnaLNZPRrwo
    Jan 2007
    723
    Thank you sooo much! Do the reference plates need to be made from a ferrous metal or can I just use an aluminum block?
    Aluminum is possible but the detection distance is much smaller than ferrous metal (iron or steel). Ferrous material is prefered.
    This doesn't need to be a solid block: a small disk of, say, 10mm round and 2mm thick, placed on a wooden or plastic column will work too. As long as it stands quite solid on the material during the autofocus-procedure.
    The other referenceblock i use for adjusting the sensor during a lens-change is just a block of aluminum 10mm thick. This 10mm is exactly the distance between the nozzles tip and the focal point (in my case, i made it that way..)
    Kees
    Jan 2007
    723
    The laser tip we have is not designed that way. Ours is fixed in place and does not move up and down. That is good information on the ferrous metal height plate. I might make the body from al and the top from epoxied sheet steel. I ordered 4 of those sensors and they should be here in about 2 weeks. I also have to fabricate a means to hold one on the laser. If the height gauge works out then I might replace several of the other limit switches with these as well.
    May 2010
    28
    Re: Where to get a laser height focuser?
    I know this post was a little outdated. But see what we have done so far. See our new RTAF (Real time auto focus)
    https://www.youtube.com/watch?v=rjhTnPCnJMo
    Marco
    LightObject
  1. Disable Height Regulation on a Trumpf Laser?
    By CLT-Tech in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-21-2023, 04:21 PM
  2. Replies: 1
    Last Post: 01-29-2013, 05:22 AM
  3. Torch height controller(THC) for YAG laser
    By larryy1022 in forum News Announcements
    Last Post: 01-15-2012, 02:34 PM
  4. how to control height with laser cutting.
    By webcruiser8 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2011, 09:19 PM
  5. Oddball stepper question - auto-focuser
    By Rhodan in forum CNC Machine Related Electronics
    Last Post: 11-11-2009, 09:07 PM
