588,172 active members*
4,146 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Help finishing mold.
    Aug 2012
    4
    Hi Guys,
    I am getting some parts machined at the moment for some molds.
    They are made out of a layered stack of MDF into a shape pretty well like this:
    Now I am wondering how I need to finish the wood, and what steps I need to go through before casting off of it each time. I will mainly be making the parts from fibreglass, but may attempt to do it from concrete at some point.
    So I am wondering what products I need, and in what order do I need to do them in? The parts need to be very smooth.
    Also, will there be any issue with the MDF possibly swelling from the PVA used to build up the mold?
    Thanks,
    Ryan
    Sep 2005
    1660
    MDF can be tricky. I've used a spray on high-build filler to surface the mold and then sand and polish that back for fine detail. You can wax it and use it for fiberglass and I would assume concrete would be no more difficult to use w/ the same process?
    Fwiw
    JerryFlyGuy
    The more I know... the more I realize I don't
    Oct 2008
    199
    Hi Ryzaa,
    Have you progressed any further with your project?
    What is it that your making exactly?
    cheers
    Liam in Tassie
    http://www.cnczone.com/forums/cnc_wood_router_project_log/101936-5_axis_build_full_steam.html
    Feb 2011
    423
    If fiberglass is the material the end product will be, why not use fibreglass for the mold as well. This will possibly be the most cost effective compared to durability.
  1. Replies: 0
    Last Post: 07-13-2012, 08:27 AM
  2. Finishing a Mold Cavity
    By eliot15 in forum GibbsCAM
    Last Post: 08-05-2011, 02:52 AM
  3. Best way to prep mdf mold for making female mold
    By konalure in forum Moldmaking
    Last Post: 10-29-2009, 02:48 PM
  4. Mold Finishing prior to forming
    By Cafemondo in forum Vacuum forming, Thermoforming etc
    Last Post: 08-21-2007, 03:37 AM
  5. Making a positive mold from a negative mold - how?
    By SRT Mike in forum Moldmaking
    Last Post: 03-29-2007, 10:30 PM
