588,616 active members*
4,645 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Apr 2005
    252
    laser 1200-60W
    New machine picture
    Dec 2005
    484
    Why do they cool the HR mirror? That is weird...
    Is the OC also cooled? Any idea of what gas mix is used in these lasers? I don't suppose they use Xenon do they? I have heard it extends tube life, but it costs as much as gold per ounce (or more?). Synrad uses like 7% or so!!!
    Apr 2005
    252
    It uses the mobile water cooling,Has the temperature the control,High or lowers in the scope which may controlDoes this the goal is the security and the time reason
    Uses CO2 the gas,This and Sy is not same,Because its price is very low,Not need replacement gas,Only needed to purchase newly to be possible once more,Because he needs $260USD merely,But Sy 60W laser in here need $4000,Therefore he is the good choice,Is my DIY good choice
    Apr 2005
    252
    More pictures
    Apr 2005
    252
    Apr 2005
    252
    3
    Apr 2005
    252
    4
    Apr 2005
    252
    5
    This is uses the model airplane which my DIY laser machine does
    Attached Thumbnails Attached Thumbnails S5000073.JPG   S5000077.JPG   S5000078.JPG
    Dec 2005
    484
    Is possible to get new 60 watt tube for $260? Can give details please?
    Dec 2005
    484
    Also, Synrad 60 watt laser is not $4000. Try $7000+
    Dec 2005
    484
    You would get a better edge (less char) on those balsa pieces if you could use 20-50psi of clean dry shop air out of your CO2 lens nozzle.
    Apr 2005
    252
    CO2 Laser Technical Parameter
    Length (mm):1200(250,400,450,500,600,700,800,1000,1400,16 00,1800)
    Mode(mm):Lower mode
    Outer diameter(mm):Φ54±2(30,36,50,54,60,65)
    Ignition voltage(KV):24(7,11,12,13,18,19,20,22,24,26,28,30)
    Operating voltage(KV):16(6,9,10,11,12,13,15,16,17,18,20)
    Operating current(mA):24(5,12,14,15,16,18,20,22,24,26,28,30)
    Power Output(W):60(4,12,16,18,24,30,35,40,60,75,90W)
    Power stablility:≤±5
    Quality factor M2 1.2±0.2
    Laser pattern TEM00 or TEM01
    Light beam diameter lens
    Design life 10,000 hours
    He needs a power source:I purchase the price is $610USD
    Possible choice:$260+$610=$870USD.
    I have purchased,Produces the merchant to tell me it the life is 10,000 hours,6 months,Is not SY $7000,The cost is lowConforms to my requirement
    He and SY is the different typeHas the difference the model
    Thank you about balsa pieces and the less char suggestion
    1st, input voltage: AC 220V±15%,
    AC110V±15% (when ordering should explain specially);
    2nd, maximum output voltage: DC 28KV (1250mm);
    3rd, maximum output electric current: DC 20mA (1250mm);
    4th, speed of response: <= 1mS.
    5th, TTL level switch control: DC 5V;
    6th, protects the switch: (1) lacks the water protection, (2) has flowed the limit protection, (3) overvoltage protection;
    7th, the laser output adjustment (uses advanced PWM control technology):
    (1) the 0-5V simulated signal, the control laser energy adjustment (coordinates software);
    (2) TTL level switch control frequency output: DC 5V;
    (3) by potentiometer manual regulation laser power source output current.
    8th, use environment: Temperature (-10 ~ 40) ℃, humidity: <= 85%.
    9th, external dimensions: 265×225×80 (long * width * is high) mm.
    Apr 2005
    252
    I make the laser machine may process a 1200*800 millimeter material,In superficial carving pattern,Design,Or cuts 20 millimeters thickness the nonmetallic materialsThe efficiency is high
    Feb 2004
    2337
    Thanks for the pictures. They are very good
    Do you make the planes to sell, or just for hobby?
    Apr 2005
    252
    My hobby interest in airplane and CNC,LASER.I hoped becomes these my work.
    And my US and Europe sell my model and the machineSeeks is purchasingWill promote my future work industryAnd knows more friends.
    Apr 2005
    252
    9
    Apr 2005
    252
    model airplan
    Apr 2005
    252
    If you want to purchase this machine,How much money do you want to pay for him?
    I want to sell this machine
    Mar 2004
    368
    Quote Originally Posted by hkxy
    I am interested in purchasing the machine. How thick an object can it cut? What is the power on the laser? Can it mark anodized aluminum? And do you have any idea how thick acrylic it can cut? Could it cut thin rubber sheet to make gaskets from?
    Does it have a rotary attachment, or is there a rotary attachment available? What is the cutting area?
    I honestly dont know what price you are looking for the machine, do you have an asking price you would like for it? I'm assuming its used, correct? So maybe some discount from new taking into account the use on the machine would be fair?
    Apr 2005
    252
    Thanks!
    General, he cuts the plank 0-6 millimeter, below the plastic PVC-PMMA20 millimeter.
    The laser energy is 70W.
    He may not mark the positive electrode aluminum,But may choose the different YAG fitting,He is may,Moreover may choose 100-200W the laser,He may cut the metal,Even steel plate
    I have not done the propylene diethylene glycol dinitrate experiment, but acts according to experiences, below plastic material 20 millimeters, if you replace 80-150W the laser, may cut 50 millimeters below plastic films.
    May cut the rubber gasket, moreover this is his superiority.
    This rotary appendix needs to prearrange, about 7-14 day.
    1200*800 millimeter. Moreover also may prearrange any size the machine. 0-6000 millimeter.
    $8500-12000 US dollar,According to time and exchange rate,Components,Serves the difference in price change,If you need,I can give you the very good price,Because of mine plant production this machine,
    You thought this price may accept?
    His use is simple,Directly in aotucad,In coreldraw direct use
    If you have the interest,We may discuss his use,Software,Components,Laser,CNC,Training,Service ,Service...
    May consider the exposition, the business agent, the sales price discount.
    Has used whether the machine does amortize the new machine is more worthwhile than
    My here does not sell the old machine,But from use angle,The old machine is worthwhile compared to the is new machine,If you need the old machine,I might seek in before customer there,Our country hopefully sells the old machine,I may inform you,You hoped how much money buys the old machine?
    http://www.rcuniverse.com/forum/m_38...tm.htm#3885014
Page 1 of 2 12
