587,754 active members*
3,229 visitors online*
Results 1 to 7 of 7
    Aug 2003
    329
    CNC Touch Off Plate
    I recently made a batch of CNC touchoff plates that have some unique features. Here is the information if anyone is interested.
    http://www.themakersguide.com/home/p...-edge-finder-2
    Bill
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
    Aug 2003
    329
    Also check out the Mach3 tutorials. http://test.themakersguide.com/home/tutorials/module-2
    Aug 2003
    329
    Here is a video explaining what it does.
    - - - Updated - - -
    Aug 2003
    329
    Using Tapered Bits - CNC Touch Off.
    Dec 2007
    44
    Nice work. Are these for sale?
    Aug 2003
    329
    Quote Originally Posted by kiramunch@sympa View Post
    Thank you. Yes these are for sale at The Makers Guide - Triple Edge Finder - THE MAKERS GUIDE.
    There is an introductory sale that ends on 04/15/2013 so it's best to get one soon.
    Bill
    Oct 2013
    Wasn't sure if there is a support thread for the makers guide but was having a little trouble so just a quick question or two.
    Installed the blue probing screen like the videos but the probe doesn't set the DRO's to zero, I have to manually zero X&Y once the probe has touch the 4 sides and is centered.
    The Z axis will touch off once and then on the second probe will try to drive the probe into the plate.
    Also downloaded version 3.3 of the big-tex screen but the screen loaded thru Mach says 3.2.
    Does this sound like a screen issue, machine setup issue or operator? Have used the standard Z probe with pcb plate under the original mach3 screen with no problems. (maybe need to remove old code.)
    Thanks, John
  1. Touch-off plate for CNC router?
    By CanSir in forum LinuxCNC (formerly EMC2)
    Last Post: 03-28-2019, 11:53 PM
  2. Touch off plate problem
    By raf61 in forum LinuxCNC (formerly EMC2)
    Last Post: 01-01-2012, 10:16 PM
  3. Touch off plate
    By rich_cree in forum Benchtop Machines
    Last Post: 06-03-2010, 06:05 PM
  4. electronic touch-off plate
    By project5k in forum Benchtop Machines
    Last Post: 02-25-2009, 08:20 PM
  5. Touch Off Plate
    By gunlocators in forum Benchtop Machines
    Last Post: 10-07-2008, 07:25 PM
