588,566 active members*
4,853 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Bolt hole spacing on a flange
Results 1 to 5 of 5
    Jul 2005
    4
    Does anyone know what tool is used to space bolt holes evenly whem drawing a flange in autocad ? The holes need to be space evenly around a circle .
    Feb 2006
    313
    circular/polar array. I don't recall the acad terminology for sure. If doing 3D, it's easiest to make an over length cylinder, array that, then subtract each one from the solid.
    (that's how I'd go about it, anyway )
    Tiger
    May 2005
    1810
    ...or you can draw the bolt circle centerline and use 'divide' - divides the entity into whatever number of equal length segments.
    Array is the better option as the divide command leaves invisible points in your drawing and can be troublesome if they are not removed.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    35538
    Quote Originally Posted by mxtras
    Scott, they're not invisible, they're just hard to see.
    Apr 2003
    416
    I agree the array command is the way to go.
    I don't like those small points either...
    The points can be set to a different style / size using "ddptype". I set my template drawing (acad.dwt) to use a .02 size in absolute units.
    Bill
