603,802 active members*
5,447 visitors online*
Results 1 to 15 of 15
    Mar 2012
    34
    24x48 Budget Build, "SINE".
    My first CNC was a mess, so I've decided to build another. I made an earlier advice asking for advice and got a number of great responses (http://www.cnczone.com/forums/diy_cn...ign_start.html); I've since begun its construction.
    As a high school student, I don't have too much engineering and machining experience (or cash, for that matter). If you have any suggestions, I'd love to hear them.
    With any luck, the final product should look a bit like this.
    Mar 2012
    34
    (Most of the parts have already been cut out/machined, so this build should hopefully go fast)
    The base came together quickly thanks to sheet metal screws (I'm not sure if they were ever meant to go through 1/8" thick steel, but it happened nonetheless ). It, in a nutshell, is made out of two sections of 1.5" (1/8" thick) tubular steel with a slab of 3/4" plywood bolted on top.
    Mar 2012
    34
    I also began assembling the gantry of the machine. My homemade bearings worked out surprisingly well!
    Mar 2012
    34
    The legs of my machine got put on next along with a few 2x4 reinforcements on the underside of the bed. A few (unshown) braces were also added to stabilize the legs.
    I might add two extra legs to the center of the machine later on.
    Mar 2012
    34
    I completed the carriage next and installed it on the gantry. I also stuck the (incomplete) Z axis on it.
    The bearings look a bit on the tight side; should I keep them like that, or loosen them up a bit to prevent fatigue?
    Mar 2012
    34
    I got a bit of work done on the gantry and added its side panels along with a second set of bearings along the bottom.
    I also encountered my first major problem; after an unsuccessful fight with a harbor freight drill press (I sadly don't own a lathe yet), I've managed to bore both of the gantry AT5 pulleys off center. The only solution that I can think of is to get two more bored to the right size from Misumi, but that'll cost me another $50. Either that, or I get two more 0.25" bore pulleys from Econobelt and try to find someone with a lathe to do the job right.
    Jan 2008
    1556
    It's looking pretty decent.
    Haven't you reduced your Y axis travel a lot by having the stepper mounted in board like that?
    Mar 2012
    34
    Yep, I did lose 2 1/2 inches from that decision. I have 23" of travel, though, so I can still work well with 2x4 sheets (which was its main purpose).
    Jun 2012
    817
    Quote Originally Posted by Cheeseduck View Post
    Putting it out-board would only take some longer screws and stand-offs. Definitely worth it if you can pick up 2 1/2" on the Y travel. That's an extra 120 square inches of cutting area for your machine and you can use all of that 2'X4' sheet and a bit to spare. And it will look better engineered.
    Mar 2012
    34
    @Devastator: I can't change my design now since all of my parts are already cut, but I think that fix will be my first cut when I finish this!
    I've added the first belt to the gantry, and added the 4 belt holders for the belts that move the gantry itself. I've also added all of the drivers, and hooked up the X axis. The X axis now has movement (!), but is pretty noisy since not all of the bearings have contact; I'll have to tram it soon. The Z axis nut is also in place. All I need now are the two gantry pulleys and a shaft coupler to get my machine fully operational.
    Attachment 191854
    Attachment 191856
    Attachment 191858
    Attachment 191860
    Oh, and one last question: My belts are steel reinforced Brecoflex 16mm AT5 belts. How much can I tension these?
    Jan 2008
    1556
    Looks like it's coming together nicely
    I'm interested as to why you chose to put the stepper drivers at the stepper? My thinking it's that it adds weight and exposes the driver to a harsher environment / risk of damage compared with having the drivers in a case and running cable to the steppers.
    Nov 2007
    483
    Perhaps at the time is seems easier to wire up the stepper but in the end you have to run wires to the bob. Centralizing the electronics in one location in a protective box is the way to go.
    Very cool build.
    Quote Originally Posted by pippin88 View Post
    Mar 2010
    27
    Nice build, like the bearing trolley design you used. Been puzzling over this one for awhile, need to change out my x axis rails and bearings for something easier, stiffer and adjustable. This maybe exactly what I'm looking for. Hate to spend money on a ready made solution.
    Keep up the good work :cheers:
    Mar 2012
    34
    Alright, I'll find an old box or something similar and put the electronics in that. Watching a $42 driver shake itself to pieces doesn't sound like fun to me.
    On a bright note, I finally received my $3 chinese shaft coupler in the mail and finished up the Z axis. It is slow since it uses allthread, but ACME is on my list of future addons.
    On a not-so-bright-but-expected note, my router screams like a banshee at full speed. My neighbors will not be happy with this.
    Mar 2012
    34
    I finally got my pulleys bored out and installed. In addition, I got most of my electronics bundled up on a separate board and hooked them up to all of the axis. I then battled my way through hundreds of bugs and small fixes to cut out new belt holders since my old ones were rather flexible. I guess that they could be considered my first cut! I then installed homing and limit switches along with a cardboard estop and added a shelf to hold it all. Although fully functional at this point, my machine still needs some form of workholding and cable management. I've been thinking of embedding Tee nuts around the perimeter of my table since T-slot is too expensive for me and hanging my cables off of a piece of spring steel. Any suggestions?
    Attachment 196744
    Attachment 196746
    Attachment 196748
    Attachment 196750
    Attachment 196752
  1. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-25-2013, 12:57 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Small CNC build thread 20" x 18" x 4"
    By metalworkz in forum DIY CNC Router Table Machines
    Last Post: 01-15-2013, 03:29 AM
  4. First build 8020 60"x24"x5" Board Shaper
    By dlyork in forum DIY CNC Router Table Machines
    Last Post: 09-07-2010, 02:32 PM
  5. Programming a Router to cut a "sine wave" in hardwood?
    By ZeroStar in forum G-Code Programing
    Last Post: 12-04-2009, 04:48 AM
