588,495 active members*
4,348 visitors online*
Results 1 to 9 of 9
    Jun 2013
    454
    looking for st george and the dragon
    G'day all,
    I have been trying to make an image of st george and the dragon to do a bas relief. Its my patron saint..
    Haven't had much luck creating a hight map, so was wondering if anyone had an image they would like to share?
    I just cant find an image thats clean enough of large enough to work with..
    Cheers,
    Steve
    Jul 2012
    43
    How about this one?
    How big do you need it?
    Cheers
    Wolffie
    Jun 2013
    454
    Oh whow,
    As large as possible if that's ok please... big enough so if I need to double its size it won't pix-elate.. Ultimate goal is to make something that is at least 16" x 16".
    Many thanks ...
    Steve
    Quote Originally Posted by Wolffie View Post
    How about this one?
    Cheers
    Wolffie
    Jul 2012
    43
    What software are you using?
    Attachment 197290
    This one is about 640mm square, sorry, don't do inches :banana:
    Cheers
    Wolffie
    Jun 2013
    454
    That's 2 ft 1 13/64 inch or 25 13/64 inches - using bmp bender - jdpaint - m3..
    Even though millimeters are simpler to use - I just can't get rid of inches (sort of gives away my age) it took me too long to learn what inches, feet, yards, chain, lengths miles and gallons where... before someone decided what I had spent most of my childhood learning was no longer relevant... I'm still good with the Americans though :P...
    The height map from that would be awesome if you don't mind sharing it - the rest I can do from there...
    Regards,
    Steve
    Jun 2013
    454
    As a by the by what did you use to clean up the image and produce the height map?
    The best I've been able to do with a st george has been...
    Attachment 197442
    Constructing a 3d scene myself but its not very good... it needs a lot more work - background has height information which needs to be removed st george looks more like a gladiator, dragon needs more work and detail etc etc etc ..
    Jul 2012
    43
    Don't know any of those programs, I use Aspire4 from Vectric.
    I agree it is not a very good picture you have, I tried to remove the background but the colours are too interlaced. Did you convert it to a negative?
    I also agree that St George looks terrible, more like a court jester than a warrior
    Well, I grew up with metric, came here in 1968 and had a hellofaproblem working out Imperial. I was soooo happy when they changed to metric.
    Thank goodness for calculators when I work with american models
    Cheers
    Wolffie
    Jun 2013
    454
    Regal Robotics 500 Series - Large Scale 5-Axis CNC Router by Donnie Weir ? Kickstarter
    For anyone that's interested looks like an interesting inexpensive 5 axis solution... by the way the project is going it looks like it will make and exceed the amount needed for funding...
    I have no idea though if it is a solid machine...
  1. Thanks To Gus & George/Machintek
    By greg b in forum Bridgeport / Hardinge Mills
    Last Post: 06-21-2012, 12:39 AM
  2. Dragon cut question
    By tentonjj in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-15-2011, 12:51 AM
  3. George - connector
    By wjr09 in forum Bridgeport / Hardinge Mills
    Last Post: 05-01-2011, 02:39 AM
  4. George
    By doctordemo in forum Bridgeport / Hardinge Mills
    Last Post: 09-11-2010, 02:46 PM
