587,990 active members*
5,635 visitors online*
Results 1 to 2 of 2
    Aug 2011
    53
    A different approach to a thrust bearing
    I started to make the thrust bearing mod to my ver.1 machine but decided I did not want to loose any more Z travel. I came up with a way to install a thrust bearing and gain about 1/2" Z travel at the same time. It consists of a bearing mount, a couple of spacers, a set collar, and 2 radial thrust bearings that I got from Grainger's. The upper bearing sits down in an enclosed recess where it is not open to any dust. The only negative is that you need a lathe to cut the cavity in the mount for the bearing and the recess on the spacer for the little lip on the motor. But most guys with a CNC machine either have a lathe or know a buddy that has one. I used 3/4" aluminum for the parts. Since the motor was raised up about an inch, I had to use some all thread for the bolts. I have not used it much since the modification, but so far it's working fine.
    Attachment 207290Attachment 207292
    I don't make mistakes ... I make 'unintended engineering design changes'.
    Aug 2006
    132
    A good innovative approach. Well done.
    My build is at the 2.0 stage, have the 2.1 updates, and now a second choice -- and I also have a lathe.
    Any landing you can walk away from is a good one.
    -=Doug
    "IT ≠ IQ " Starwalt 1999
  1. thrust bearing ?
    By slowlearner in forum Fadal
    Last Post: 07-17-2011, 03:08 PM
  2. thrust bearing nut wrench
    By dreammstr6 in forum Bridgeport / Hardinge Mills
    Last Post: 12-25-2010, 01:55 PM
  3. thrust bearing for bk/bf setup?
    By 15mgtar in forum Mechanical Calculations/Engineering Design
    Last Post: 09-13-2009, 09:23 AM
  4. Thrust bearing numbers
    By geebee1912 in forum Fadal
    Last Post: 08-25-2007, 06:43 PM
  5. What do you think of this thrust bearing design?
    By cncadmin in forum Benchtop Machines
    Last Post: 06-03-2004, 02:20 PM
