587,480 active members*
3,241 visitors online*
IndustryArena Forum > CAM Software > MadCAM > 4th Axis Changing zero from center of piece to outside
Results 1 to 5 of 5
    Sep 2012
    6
    I am trying out my 4th axis for the first time.
    My piece is milling "correctly" when I zero to the center of my stock.
    Right now I am running my machine in the air because it would just ram into my material.
    When I run it off to the side of the piece it seems to be milling correctly.
    I would like to setup it up where the zero is the outside of my stock.
    I included my model
    thanks
    May 2013
    261
    Can you reframe the question as it does not make much sense with the forth axis . It does with 2.5 and 3D . Why do you want the outside surface of the model to be zero?
    Also is your 4th axis in the y ?
    Sep 2012
    6
    I am new to using a 4th axis or rotary axis.
    I want the outside to be zero on the outside because if it is based on the center of the stock then the machine rams into the stock.
    May 2013
    261
    It sounds like you are doing a finish path before the roughing path? Is this the case? Or is it the case of you are using the roughing path but you are having the cut start too deep into the material on the first pass. if this is the case then you have 2 options
    1 lie to the madcam about your stock size by saying it is bigger than it really is then you will be doing a little air cutting before the real cutting starts
    2 or if you 5 axis version you can tell it to cut a little above the drive surface in the drive surface options box , this will achieve the same outcome.
    When I cut metal I usually have to lie to the cam in one way or the other as my cutters are so small ( less than 1 mm with a .1 mm step down that even .2 mm off on surface location will cause me to have broken cutters)
    What I would suggest to start with is buy some machinable wax and learn on that as it is way cheaper than end mills.
    MachinableWax.com
    Dec 2008
    4548
    Quote Originally Posted by zevenwolf View Post
    You'll want to leave the zero at the rotation axis. There are a few answers depending on what you are doing. (I dont know MadCam so cant really direct you in there)
    "The machine RAMS into the stock....."
    What code is doing this? Start and stop? You can setup "machine AND work coords" so starting and ending is done at different areas.
    Usually though, the CAM software has a "top" setting, so your "STOCK" is set to be the rad/diameter of the material.
    If you dont have these options, then you can set your post to "stop" at ends or toolchange positions and manually jog the z out of the way.
  1. changing axis direction in post
    By thermgood in forum Mastercam
    Last Post: 10-06-2020, 04:27 PM
  2. Changing axis readout ??
    By nelZ in forum CamSoft Products
    Last Post: 04-09-2012, 09:09 PM
  3. Changing G3 x y i j; Y: G2 X Y I J So Y movement is .15 further in X Axis
    By worldsworstfish in forum Uncategorised CAM Discussion
    Last Post: 01-09-2011, 10:38 PM
  4. z axis work piece offset
    By The CNC Noob in forum Haas Mills
    Last Post: 08-05-2009, 12:18 AM
  5. Z axis offset changing by itself
    By Rick Kight in forum Cincinnati CNC
    Last Post: 07-30-2009, 01:28 PM
