Question: Are there any other stepper motor drivers I can use with a Microkinetics CNC Express mill other than the original DR8010? I suspect I could replace them with DM8010s but am not sure it is worth the additional expense.
I searched the web and the forums for an answer but did not find any. I am not an electrical engineer but can figure things out if given enough information. ![Smile](images/smilies/smile.png)
After encountering this problem I learned that I probably should have removed the cables before using the mill manually because the motor will act as a generator and send current to the electronics in the Drive Rack. I tried disconnecting the cables and noticed that it manually turns much smoother now with no resistance. When the cables are connected there is a definite felt resistance when I turn it manually.
Before I describe the problems I am encountering, here is some machine information:
Microkinetics CNC Express Mill
Model # 999-6500-000
Serial # 0119
Motion Controller:
MN400 (except mine is not USB)
Stepper Motor Drivers: DR8010
Stepper Motors:
- one is: 1.85V 6.6A slosyn type kml08f318
- The other two have faded labels so I am not sure but look like this
Background:
I purchased this cnc mill used several years ago and it was working fine. I then only used it manually for the next couple of years. This weekend I went to use the CNC capabilities and encountered the following problems:
Problem description:
• One way only computer controlled motion on the Z axis
• No X axis motion
• Full Y axis motion
• Swapping cables from the mill to the back of the Drive Rack verified that motors on mill are working
• Removing the cover from the Drive Rack revealed that one stepper motor driver (DR8010) was not getting power
• Found a burnt fuse for that DR8010
• Replaced with a fuse from another DR8010 and powered up the Drive Rack which resulted in the fuse immediately blowing
I do have an ohm meter and saw on another forum how to check signals to the motors so I will do that to confirm the problem.
After that I am thinking of moving the partially working stepper motor driver to the other not working position to see if the problems follow it. Then I might try moving the good one to other positions to see if they work. I am hesitant to risk breaking the one that is working as part of my diagnostics.
Thanks in advance for your help.
