588,231 active members*
4,203 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Videos > CNC Woodworking G-Code creator
    May 2005
    53
    I have a cnc router and have used it heavily in my shop because it is an extremely useful tool. However, it is not really the quickest and easiest tool to use. To make a simple cut, I have to go through as many as 3 programs, make a few calculations, set up the workholding, etc, etc. It was getting old for simple work. I was just about ready to go out and buy a sawstop and a router table, but then I thought, why not make a simple program that will make the router into a very easy tool to use for the most common kinds of woodworking operations (jointing, straight line cuts, profiling, slotting, rabbits, datos, dove tails, mortis’ and tenons, etc). Basically, anything that can be defined by a very simple and small set of numbers. I can quickly go through the settings, generate some g-code and go. I don’t have to draw, do tool paths, and then go to the machine and hope I didn’t make a mistake.
    I know that this has to be an impediment for others too, so I decided to write the code in python and make it open source so anybody can use it, contribute to it, and modify it to suit their own needs. No more closed source tools that only do just a few things. Also, this is free as in speech and beer for non-commercial applications (for the 21st century woodworker hobbyist).
    Here is the first tutorial:
    It's nothing that will do complex stuff, but most simple operations aren't that complex. I hope to get more use out of my cnc and save time doing it.
    code is evolving and is available at github.
    May 2005
    53
    Here's a demo showing how easy it is to use the cnc as a jointer with the software.
    May 2005
    53
    I finished the straight line cut tutoral. Check it out:
    May 2005
    53
    Here is a demo of the straight cut. just one of the many operations this could be used for.
  1. Key Creator 12 Rotation of entities
    By alaskagoldman in forum Uncategorised CAD Discussion
    Last Post: 01-17-2014, 07:06 PM
  2. CREATOR CJ-120 GETTING OLD?
    By keen in forum EDM Discussion General Topics
    Last Post: 06-25-2009, 08:39 AM
  3. Key Creator
    By gosserwb in forum Uncategorised CAD Discussion
    Last Post: 05-22-2007, 02:08 PM
  4. HPGL or PLT Creator
    By tburkard in forum Uncategorised CAM Discussion
    Last Post: 11-28-2005, 10:15 PM
