I already posted this question on the Dynomotion Yahoo group but thought I'd post here for a few more eyes to have a look so Tom, no need to re-respond
In the process, I'd really like to add encoders to my stepper system to be used in closed loop mode. If the homing between Mach 3 and Kmotion is similar, I may used the Mach 3 plug in in open loop or simply missed step mode while I'm getting used to Kmotion and then ultimately switch over to Kmotion once I have all of the macro functionality I have in Mach 3 replicated in Kmotion.
I'm planning on adding 3 encoders, on the X,Y, and Z axes, either 2000 or 4000 line count depending on what I hear in terms of performance requirements. Encoders will be single ended wired directly into the Kflop as I simply can't afford something like a kanalog right now.
The rest of my setup is based on a G540 with the standard parallel port wiring. Here's the wiring I intend on doing. The Kflop box will have a DB25 output that plugs into the G540 and then 3 additional connectors for the encoders. I might add an mpg into the kflop as well as I've gotten used to using the Shuttle express for certain machining operations.
Could you guys have a look at this wiring setup and let me know if it looks pretty good?
TIA
-Andy
-Andy B.
http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
