588,566 active members*
5,368 visitors online*
Thread: Tool tables
Results 1 to 5 of 5
    Nimrod Guest
    Tool tables
    How can you bring an existing tool data base built in MS ACCESS in to a Mastercam tool table? Is it possable in Mastercam?
    Thanks Nimrod "the mighty hunter before the Lord"
    Apr 2003
    1876
    Re: Tool tables
    Yes it's possible.
    The Access file will have to be formatted correctly for MC to read it.
    Once it's formatted properly, go to NC Utils, Define Tools, Library, then right click, and select Create Library from Text.
    HTH
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2003
    1876
    p.s., Here's a sample of the formatting, taken from a
    library that was converted to text. (The opposite of what you're doing.)
    Code:
    # TOOL LIBRARY FORMAT - Tue Jun 03 07:38:47 2003
    # = comment if 1st character in line
    # line 1 - TOOL (start of tool definition)
    # line 2 - tool material (1-HSS, 2-CARBIDE, 3-COATED CAR, 4-CERAMIC, 5-BORZON, 10-UNKNOWN)
    # line 3 - tool comment
    # line 4 - tool name (geometry reference for backplot)
    # line 5 - tool manufacturer
    # line 6 - chuck designation
    # line 7 - tool_no, tool_type, rad_type, dia, crad, thds, tip_angle,
    #          dia_off, len_off, feed, plunge, retract, rpm, coolant, n_flutes, bottom_turret, station
    # line 8 - Drilling attributes (see tool_type in line 7 above)
    # line 8 - cycle, peck1, peck2, peck_clr, chip_brk, dwell, shldr_angle, root_dia (tap), bore_shift
    # line 8 - Milling attributes (see tool_type in line 7 above)
    # line 8 - cut_able, rgh_x, rgh_z, fin_x, fin_z, tip_dia, root_dia (thd mill), thd_angle
    # line 9 - pilot_dia, flute_len, oa_len, shldr_len, arbor_dia, hldr_dia, hldr_len, spindle_ccw, sfm, fpt, metric
    # line 10 - Holder type, Work offset, Initial dir vector[3], Head offset[3], Tool offset[3]
    # (tool types)          (tool capabilities)   (canned cycles)
    # CENTER DRILL     1    ROUGH & FINISH   0    SIMPLE DRILL  0
    # SPOT DRILL       2    ROUGH            1    PECK DRILL    1
    # DRILL            3    FINISH           2    CHIP DRILL    2
    # TAP-RH           4                          TAP           3
    # TAP-LH           5    (tool corner radius)  BORE1         4
    # REAMER           6    NONE             0    BORE2         5
    # BORING BAR       7    CORNER           1    MISC1         6
    # COUNTER BORE     8    FULL             2    MISC2         7
    # COUNTER SINK     9
    # END MILL FLAT   10    (coolant types)
    # END MILL SPHER  11    OFF              0
    # CHAMFER MILL    12    FLOOD            1
    # FACE MILL       13    MIST             2
    # SLOT MILL       14    TOOL             3
    # CORNER RAD MILL 15
    # DOVETAIL MILL   16    (spindle direction)
    # TAPER MILL      17    CW               0
    # LOLLIPOP MILL   18    CCW              1
    # END MILL BULL   19
    # BLOCK DRILL     20
    # *** DO NOT REMOVE LINE NUMBERS OR DELETE ENTIRE LINES!              ***
    # *** ALL TOOL DEFINITIONS MUST CONTAIN 10 LINES AND THE 'TOOL' LABEL! ***
    1 - TOOL
    2 - 1
    3 -  1/8 CENTERDRILL
    4 - C:\MCAM91\MILL\TOOLS\CTRDRILL.MC9
    5 -
    6 -
    7 - 1 1 0 0.125 0. 0. 90. 0 0 1.026816 1.026816 1.026816 2139 1 2 1 -1
    8 - 0 0. 0. 20. 10. 0. 90. 0. 0.
    9 - 0. 2. 3. 2.5 0.125 2. 1. 0 100. 12. 0
    1 - TOOL
    2 - 1
    3 -  1/4 CENTERDRILL
    5 -
    6 -
    7 - 2 1 0 0.25 0. 0. 90. 0 0 1.0696 1.0696 1.0696 1069 1 2 1 -1
    9 - 0. 2. 3. 2.5 0.25 2. 1. 0 100. 25. 0
    1 - TOOL
    2 - 1
    3 -  1/2 CENTERDRILL
    5 -
    6 -
    7 - 3 1 0 0.5 0. 0. 90. 0 0 1.0696 1.0696 1.0696 534 1 2 1 -1
    9 - 0. 2. 3. 2.5 0.5 2. 1. 0 100. 50. 0
    1 - TOOL
    2 - 1
    3 -  1/8 SPOTDRILL
    4 - C:\MCAM91\MILL\TOOLS\SPOTDRIL.MC9
    5 -
    6 -
    7 - 4 2 0 0.125 0. 0. 90. 0 0 1.026816 1.026816 1.026816 2139 1 2 1 -1
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Nimrod Guest
    Smile
    thanks Rekd I have to see now if I can get my MSACCESS tool table format to come out like that.
    Apr 2003
    1876
    You're welcome.
    If you need a hand with Access, and I have the time, I'd be glad to help.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  1. HELP Tool changer problems
    By ddprecision in forum Haas Mills
    Last Post: 07-18-2016, 02:30 PM
  2. Tool length sensing!
    By Swede in forum FlashCut CNC
    Last Post: 05-07-2013, 04:38 AM
  3. Miniature Automatic Tool Changer
    By 1ctoolfool in forum News Announcements
    Last Post: 04-18-2005, 11:56 AM
  4. Haas Vf-2,macro For Tool Life
    By Tulak in forum Haas Mills
    Last Post: 10-22-2004, 03:06 PM
  5. Tool Changer Problems
    By Snel in forum Haas Mills
    Last Post: 08-11-2004, 02:56 PM
