588,658 active members*
6,183 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G-REX > G100 + Mach3 2010 screen auto tool zero
Results 1 to 5 of 5
    Jan 2007
    37
    Does anyone use Geckodrive G-Rex G100 with Mach 3 (2010 screenset or regular) and have a WORKING auto tool zero macro?
    My touch plate probe is set up on pin 15.
    Here's the 889 macro...
    Message( "Auto Zeroing..." )
    If IsSuchSignal (22) Then
    code "G31 Z-3 F20" // Moves probe down 3 inches
    While IsMoving()
    Wend
    Call SetDRO( 2, 0.625 ) // sets z to zero assuming plate thickness is 0.625"
    code "G1 Z1.0" // Retracts Z 1 inch.
    End If
    Problem is.... this macro works perfectly only ONCE. Second time it retracts way more than 1 inch and eventually hits the limit switch on the Z axis.
    Any ideas what could be wrong? Or should we conclude that Grex G100 auto tool zero macro will never work with mach3?
    35538
    Re: G100 + Mach3 2010 screen auto tool zero
    It looks like you modified my M889 macro? By chance are you in G91 mode when it crashes. The default M889 macro has code to prevent it from crashing into the switch, provided you home the Z axis first. Not sure how much of the original macro you're using, if any?
    It's also possible that the G100 doesn't support G31 properly. If that's the case, you may not be able to get any macro to work.
    Jan 2007
    37
    Hi Gerry,
    My "distance mode" is set to Absolute (G90) and my IJ mode is set to INC (G91.1).
    I am trying out a macro from cncrouterparts. I tried using your macro that came with the screenset and it resulted in same problems. Basically any macro I try has same problem. First touch down is fine. Second touch down immediately after results in Z axis moving up way too much.
    Any ideas what I can do? Mach 3 version is 3.043.066
    Is it possible that this is an issue that has never been solved with mach3 and grex?
    35538
    Grex support in Mach3 was never finished and Mach3 support for it was abandoned many years ago.
    Keep in mind that motion controller plugins can be sensitive to different versions of mach3.
    The only thing you can try would be an old version of Mach3, from when the Grex plugin was written. I doubt it will work, though.
    Your only other option would be a different motion controller.
    Jan 2007
    37
    Gerry, that's what I'm thinking.... although i'm happy with GREX G100 and it's awesome, i do notice that it is a pain to run with Mach3 and some things don't work. I'm not able to do auto-tool zero and reffing all axes at the same doesn't work. I have to ref X, Y, Z individually.
    What other controllers are good out there with a lot of support?
    I'd like to use an ethernet port so i guess Ethernet SmoothStepper is my only choice, right?
  1. Mach3 2010 Screen set
    By ger21 in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-12-2024, 06:45 AM
  2. Mach3 ATC & Auto Tool Zero
    By KNA in forum Mach Software (ArtSoft software)
    Last Post: 02-03-2015, 10:16 PM
  3. Mach3 and Auto Tool Zero / Mach Blue Probing by Big-Tex
    By TomiY in forum Machines running Mach Software
    Last Post: 11-15-2012, 09:24 PM
  4. Ayuda con Auto Tool Zero en Mach3
    By hmoltedo in forum Spanish
    Last Post: 12-06-2011, 02:58 AM
  5. touch screen for g100
    By jeepsterryan in forum G-REX
    Last Post: 01-23-2008, 06:33 PM
