588,069 active members*
4,616 visitors online*
Results 1 to 6 of 6
    Apr 2014
    5
    Laser Tube Wire
    Am replacing my 50 watt laser tube with a 60 watt. It is longer that the 50 and the high voltage wire will not reach so i will need to extend it. Anyone have a source or can identify the type of wire typically used here? Hopefully the attached picture of the existing wire will help. The lettering reads 22AWG LS Cable -F- LF A03.
    Jan 2008
    940
    Re: Laser Tube Wire
    You could use GTO wire like they use for Neon signs or car ignition wire
    May 2014
    28
    Re: Laser Tube Wire
    Check the cable for the voltage rating xxkV.
    You can buy the following cables off eBay with different ratings:
    20kV -> 20 Feet HV Tesla Coil Wire High Voltage Cable 24KV 20KV Belden Free Shipping | eBay
    30kV -> 22AWG 105C 3239 30KV DC Xlpe High Voltage Judd HV Cable | eBay
    40kV -> 20 AWG 105C 3239 40KV DC Xlpe High Voltage Judd HV Cable | eBay
    Good luck!
    Apr 2014
    5
    Re: Laser Tube Wire
    Thanks for the links cnz. :wave: Ordered the 22awg. 30k should be enough i would think.
    May 2014
    28
    Re: Laser Tube Wire
    Keep us updated of your progress, pictures would be nice :cheers:
    Apr 2014
    5
    Re: Laser Tube Wire
    Will do. Wire is scheduled for delivery on Tuesday so should have good news to share on Wednesday.
  1. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
  2. I changed from synrad rf laser tube to glass tube and it is not working good
    By david Neumann in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-15-2012, 03:22 AM
  3. Putting a wire into a tube
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 12-28-2006, 08:34 PM
