603,796 active members*
2,776 visitors online*
    Jul 2003
    138
    Find Center Error "Probe Ignore, Activated at call for probe"
    I am getting consistent failure when trying to find the center using both BlueTex and HOSS Mmach3 screen and the center finding macro. I have swapped out cables and computers to try and rule out the problem but now I am beginning to suspect it maybe my mach3 configuration.
    I have tried both port 10 and 13 on the C10 board along with a 2.2K pull up resistor and every time I make contact between the port and ground the light in the probe area of the screen turns on as expected. Check out the video to see the strange behavior, any help would be appreciated. I have also posted the macro code below from the screens.
    On another machine where this has worked successfully I noticed quick jogging back to the start position after making contact but this has never happened.
    ---------------------------BlueTex Code ---------------------------------------------
    Rem VBScript To center probe inside a pipe
    If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
    Code "(Probe plate is grounded, check connection and try again)"
    Else
    FeedCurrent = GetOemDRO(818) 'Get the current settings
    XCurrent = GetDro(0)
    YCurrent = GetDro(1)
    Code "G4 P1" 'Pause 1 second to give time to position probe plate
    Code "F4" 'slow feed rate to 4 ipm
    Rem Probe left
    XNew = Xcurrent - 3 'probe 3 inches to left
    Code "G31 X" &XNew
    While IsMoving() 'wait for the move to finish
    Wend
    XPos1 = GetVar(2000) 'get the probe touch location
    Code "G0 X" &XCurrent 'rapid move back to start point
    Rem Probe right
    XNew = XCurrent + 3 'probe 3 inches to right
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    XPos2 = GetVar(2000)
    XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
    Code "G0 X" &XCenter 'rapid move to the x center location
    Rem Probe up
    YNew = YCurrent + 3
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    YPos1 = GetVar(2001)
    Code "G0 Y" &YCurrent
    Rem Probe down
    YNew = YCurrent - 3
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    YPos2 = GetVar(2001)
    YCenter = (YPos1 + YPos2) / 2
    Rem move to the center
    Code "G0 Y" &YCenter
    While IsMoving ()
    Wend
    Code "F" &FeedCurrent 'restore starting feed rate
    End If
    --------------------------- HOSS Code ---------------------------------------------
    Rem VBScript To center probe Inside Diameter
    CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
    CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
    CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
    CurrentToolDiameter = GetOemDRO(43) 'gets the current tool diameter
    Call ProbeGrounded()
    Exit Sub
    Else
    Rem Probe Left
    Code "G31 X" &XNew
    Wend
    Rem Probe Right
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    While IsMoving ()
    Wend
    Call SetDro (0,0.000)
    Code "G4 P0.25"
    Rem Probe up
    YNew = YCurrent + 3
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    Rem Probe down
    YNew = YCurrent - 3
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    Rem move To the center
    While IsMoving ()
    Wend
    Call SetDro (1,0.000)
    While IsMoving ()
    Wend
    Call SetUserDro (1152,YPos1 - YPos2 + CurrentToolDiameter)
    Code "G4 P0.25"
    Code "F" &CurrentFeed 'restore starting feed rate
    Call ReturnG90G91State()
    Exit Sub
    End If
    Sub ProbeGrounded()
    End Sub
    Sub ReturnG90G91State()
    If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
    Code "G91"
    End If
    If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
    Code "G0"
    End If
    End Sub
    35494
    Re: Find Center Error "Probe Ignore, Activated at call for probe"
    "Probe Ignore, Activated at call for probe" means your probe is already being triggered when the macro calls a probing move. It probably has nothing to do with the macro's. Usually it's due to noise, or possibly wiring issues.
    Jul 2003
    138
    Problem solved by resetting mach3 configuration. I suppose I change a default setting at some point.
    Old thread same problem...
    Probe Ignore error message showed randomly on my Omio X8 recently and spent hours debugging ground wiring to discover a chip had landed on the X axis limit switch shorting the switch to the gantry. System returned to normal once I removed the debris from limit switch.
  1. Replies: 4
    Last Post: 02-03-2014, 06:29 PM
  2. Probe to find center of stock???
    By mioduz in forum Mach Software (ArtSoft software)
    Last Post: 08-18-2013, 05:48 AM
  3. "Test Probe Before Moving" Problem
    By dkaustin in forum Tormach Personal CNC Mill
    Last Post: 02-14-2012, 02:37 PM
  4. Adding Mcodes or "poor man's part probe"
    By Wade C in forum Fadal
    Last Post: 06-03-2011, 08:23 PM
  5. Mach Probe plug in what is "maximum z height for stuck probe" option do?
    By Rich05 in forum Digitizing and Laser Digitizing
    Last Post: 04-11-2009, 06:05 PM
