587,744 active members*
2,957 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > C10 bob Optical Home Switch Wiring
Results 1 to 12 of 12
    Apr 2007
    161
    I am not sure exactly how to wire my optical home switches to my cnc4pc c10 bob. I got the reprap opto switches from eBay. They have 3 wires 5v, signal and ground. I have all of my limit mechanical switches wired to 1 port so my home switches could be wired separately.
    The inputs on the c10 have 5v and the input number.
    I didnt know if I needed to wire the signal to the c10 input, 5v to 5v on the board, and gnd to common board ground.
    I dont know?
    Thanks Jason
    Nov 2010
    520
    Re: C10 bob Optical Home Switch Wiring
    Have you read this thread?
    http://www.cnczone.com/forums/open-s...made-easy.html
    I know that it deals with Honeywell hall switches, but I thought that they have the same signal out put. I made a couple of these homing switches for my cnc router. They work great. I'm using the G540.
    Good luck.
    Rick
    Feb 2007
    4553
    Quote Originally Posted by DistortedDesign View Post
    I dont know?
    Thanks Jason
    Jason,
    Yes you are correct however make sure gnd is connected to gnd not common.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2007
    161
    Quote Originally Posted by jalessi View Post
    Jason,
    Jeff...
    Thanks, I will let you know how it goes. I appreciate the response. Most of my questions never get any answers.
    Apr 2007
    161
    OK mach is not registering the change when the beam is broken. My c10 power supply doesn't have a ground only pos and neg. Do I need to connect the c10 gnd to the 120v gnd on the main power supply?
    Sent from my A500 using Tapatalk
    Feb 2007
    4553
    Follow the diagram posted to connect the ground, it is accurate.
    The C10 5 volt power supply negative is connected to the C10 ground / (GND)
    Jeff...
    Feb 2007
    4553
    I am available to help over the phone after 7:30 P.S.T.
    Jeff...
    Apr 2007
    161
    What posted diagram? Cnc4pc diagram of mechanical limit switches shows a 5v power supply that has a ground. Most 5v power supplies (in the US) are the 2 prong wall wart power supplies. I removed the negative from the c10 and connected it to ground instead. That worked, mach3 could see the optical switches changes but mach said my limit switches were triggered at all times. In the diagnostic screen showed nothing but I did see them flash one time. So they might be picking up something. Might have to add a 100 ohm resister and change the denounce? I reconnected the negative to c10 and the ground and the opticals wouldn't work.
    Feb 2007
    4553
    Post Re: C10 bob Optical Home Switch Wiring
    Evidently you missed this diagram from one of my previous posts :
    I will be available by phone after 7:30 P.S.T. typing pages and pages of dialog is not a efficient or effective use of time.
    Jeff...
    Apr 2007
    161
    Sorry Jeff, I saw the pic earlier just didn't of it as a circuit diagram. I will call but I will need your number. I am in eastern time zone so it is a bit later for me. I should still be awake. I will draw up a complete diagram of my system in AutoCAD. I need to do it anyway.
    Feb 2007
    4553
    Jason,
    I attempted to message you the phone number however your P.M. mailbox is currently not accepting messages.
    I would be happy to email the number, please send contact info to jeffalessi at gee (G) mail dot com....
    I am available for the next several hours if you have time.
    Jeff...
    Apr 2007
    161
    I emailed you my info.
  1. G540 and Optical Home Switch Configuration?
    By GEBrown in forum Gecko Drives
    Last Post: 09-12-2012, 10:13 PM
  2. Optical Home Switch circuit design - feedback requested
    By mhackney in forum CNC Machine Related Electronics
    Last Post: 01-26-2012, 09:19 PM
  3. Wiring Optical interupt switch to BOB
    By Simon C in forum CNC Machine Related Electronics
    Last Post: 02-21-2011, 05:47 PM
  4. Optical home switch wiring to G540
    Last Post: 01-19-2010, 02:31 AM
  5. Choice of Component for Optical Home Switch
    By jaybee101 in forum CNC Machine Related Electronics
    Last Post: 01-21-2009, 02:19 AM
