587,758 active members*
3,152 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Eliminating tool markings on profile operations - full depth finish pass?
Results 1 to 3 of 3
    Jul 2013
    608
    Is the solution to my problem a full depth finish pass?
    I am cutting MDF and especially alun is several passes and I can see some markings.
    To be more specific lets talk about the alum. It is 0.25" T6 being cut at 20 IPM with a 2 flute endmill with 16 passes. I don't really see 16 lines on the side of my piece, but I do see 2-3.
    I am cutting the part conventional and it looks much better then the remaining stock which by nature is getting a climb cut.
    I am thinking that I could do a full depth pass at 10 ipm and skim 0.005 or the part ? - not sure, this is where I look to you guys for help.
    PS: how do you deal with this situation when the tool is not as deep or deeper than the stock ?
    Nov 2011
    83
    Re: Eliminating tool markings on profile operations - full depth finish pass?
    16 depth passes? How deep are you profiling? 20ipm on a 2 flute? is it carbide? hat size is it? 20ipm and a 2 flute sounds awfully slow, what machine are you running? you can run an uncoated carbide 2 flute 1/2" at 150ipm at 7500rpm and .150 deep in aluminum all day long. if its profiling the smaller the width of cut the deeper it can go, i wouldnt be scared to run it 150ipm 7500rpm at 1" deep profiling off .06 width of cut, finish pass full depth at 7500rpm and 50ipm, all day long lookin like a mirror.
    Nov 2011
    83
    as far as tool not having the flute length of the thickness of the part, either get a longer cutter or run your finish pass in 2 depth cuts and rub the top of your endmill, if its a high speed endmill it wont rub since the cutter has the same diameter on the shank as the flutes, carbide is a different story, the flutes have a diameter of about .002" less than the shank so it will rub.
  1. Turn off profile finish pass
    By Forrest C in forum BobCad-Cam
    Last Post: 01-16-2014, 01:21 AM
  2. Rogue Tool Path on Finish Pass
    By Inventherm in forum BobCAM for SolidWorks™
    Last Post: 05-31-2013, 03:52 PM
  3. Cut 2D Profile pass
    By laserpilot in forum Vectric
    Last Post: 08-07-2012, 04:41 AM
  4. cut depth per pass
    By christ371 in forum Dolphin CAD/CAM
    Last Post: 07-20-2008, 03:14 AM
  5. Replies: 13
    Last Post: 01-10-2006, 03:22 PM
