588,487 active members*
6,070 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Looking for a benchtop CNC for 12"x12"+
Page 1 of 2 12
Results 1 to 20 of 26
    Jul 2014
    35
    I heard a rumor there was a benchtop CNC mill out there that had 12x36 X-Y for 5k. Anyone know what this might be? Or, any advice for getting a benchtop CNC with a larger X-Y footprint for about that much? DIY ideas? I want to make parts from 12x12 sheets and I'm not finding any benchtop machine that it would fit in. Thanks
    Dec 2011
    61
    Re: Looking for a benchtop CNC for 12"x12"+
    you are in the wrong forum, you seem to be looking for a cnc router, this is for benchtop milling machines.
    Dec 2011
    61
    Quote Originally Posted by carlowens View Post
    i suggested this in the very beginning which you dismissed. now that you seem to have come to the conclusion i made about a router you need to visit the router forums here if you want to get more in depth info, this forum is for milling machines.the router forums will have recs from users for cad/cam for their machines too.
    Jul 2014
    35
    Thanks all for the help! I ended up getting a router, so you were correct Carl. I learned I don't have enough money to mill the size parts I want to make, but I can route them. I got a Camaster SR-44 with a electro spindle. I should be able to cut AL when I get some experience.
    Jul 2014
    35
    Nope, I'm looking for a CNC machine to make real parts, not rapid prototype. I don't have room for a Bridgeport size machine.
    http://www.tormach.com/product_pcnc_...html#techspecs
    This one looks good, but I need some more Y travel.
    Jul 2014
    35
    Some posts are missing, I got an email saying this but I don't see the post:
    You will seldom find a Z travel of more than 4" on a benchtop machine. It can accept tools with shanks as larger as a 1/4". It can be used to cut non-ferrous metals (Aluminum), and softer.
    I'm new to the forum, anyway to show all or something?
    Dec 2011
    61
    a "benchtop mill" with 12x36 travels is not a benchtop machine, you need a huge mill like a bridgeport or bedmill and a new cnced one will certainly cost you 10k+. your only option is an industrial hobbies machine that you can get as a manual mill and cnc it yourself but you are still going to blow your budget. if you have to have those travels for that money look for a router or on craigs list for something used.
    Jul 2014
    35
    14" x 7.5" x 13.25" (X,Y,Z) is the Tormach, very close, granted it's probably not 5k. Just looking for ideas. This one is a benchtop mill.
    Oct 2008
    2106
    Spammers make junk posts sometimes to get past the first post limitations. Moderators delete them and all their posts as soon as they are recognized as spammers.
    As to your request. 5K for a CNC mill with 12x12 might be a bit on the lean side. Charter Oak has mill for more than twice that that can overtravel in X & Y to get that. Technically its a benchtop, but not really. LOL.
    I don't know what you are looking to do, but for a small footprint, modestly rigid machine with close to your required envelope you might look at importing a cast iron fixed gantry machine, and then retrofitting the controls if the cheap Chinese controls don't work for you. It depends on what you are planning to cut of course also. Those high speed spindles aren't worth much for low speed high torque cutting.
    So why don't you tell us what you want to do and somebody can guide you a little more effectively.
    Bob La Londe
    http://www.YumaBassMan.com
    Jul 2014
    35
    I see on the spam, thanks
    Well, I have some parts I want to make and some of the parts are circular disks about 10" diameter made from 12x12x~1 plastic. There are a hundred things I'd like to do with a CNC, but this sets the work envelope on the large end. Plastic, yes, but I don't want to invest in something that can't at least cut AL.
    I have this guy already, but not sure if it would be worth trying to convert.
    HiTorque Mini Mill, Solid Column - LittleMachineShop.com
    I under stand the 5k number is on the lean side, a buddy who sells cutting tools told me that, maybe he had some numbers wrong.
    Gantry sounds good, do you know what manufacturers to check out? Thanks
    Oct 2008
    2106
    Well, you could put a bit of money in that and have a nice little machine. The solid column is a more robust machine than the tilt column. To make that a really nice little CNC machine would cost a couple thousand, but you could skimp and do it for much less.
    Just about any machine can cut aluminum. I have an EL CHEEEEPO Chinese moving gantry that I occasionally do aluminum work on by using light cuts and fast feeds, but its a noodle.
    If you are going to be mostly cutting plastic you will want a pretty fast spindle, and probably to make friends with the guys into sign making section. They know plastic cutting like nobody else.
    If you are going to be cutting a 12" circle you actually either need a machine larger than 12" or a way to rotate the part into the cutting area.
    For $5K you could get a pretty decent moving gantry router that would also do light fast aluminum cutting. Its not a mill though. Its a CNC router. A 2x2 Velox (made in USA) is bout $5800 complete. Set it up and start cutting. There are cheaper options, but they have been around a while.
    A Sale CNC YX-3636 is a cast iron fixed gantry for less money and only a 14x14 working envelope. I think they sell for around $4k, but probably are not as ready to go, would have import and freight costs, and you may want to upgrade the controls and maybe the steppers.
    Bob La Londe
    Jul 2014
    35
    Thanks! Both those look good. I wonder what makes a a machine a router and not a mill. Can they only be programmed to run 2D shapes?
    I've thought about refitting the mill I have, but probably want to keep some means of doing manual work, drill a quick hole, etc. The main benefit of using it would be that the spindle us nice and has an R8 taper, however, not speed control feedback.
    Dec 2013
    290
    Quote Originally Posted by CosmosK View Post
    A router will have a high speed spindle, with a rpm range of 2,000-24,000. Some are variable speed, cheaper ones only run at full speed. They are not as rigid, as they are used for cutting softer materials such as wood and plastic. They make quick work of plastic, though I would look for a machine that has a variable speed spindle for plastics, I find most plastics cut best at around 6500-12000rpm. I've broken to many bits from melting the plasltic at higher rpms.
    Also single flute cutters work best in plastics, less heat build up.
    Jul 2014
    35
    Also, do you know who makes good CNC kits for the motors and scales?
    Jul 2014
    35
    Tormach PCNC 770 looks about right, granted a 12x12 part would have to be spun around and done in two halves. 600 pounds would be interesting trying to get in the basement
    Feb 2007
    711
    I would look more into a router, Unless you plan on doing hundreds of metal parts to very tight tolerances, the router should be more than enough, especially for plastic.
    If you are worried about surface finish, you can just cut a little oversized and cut it to size on a final pass.
    Oct 2008
    2106
    Here is a video clip of an El Cheapo Chinese Router milling aluminum. I put the wood router on it, pitched the cheezy rotary hand piece it came with, and I upgraded steppers and controller. If I count the computer and software I have about $2K TOTAL hardware cost invested in it. I do not recommend this machine. I just bought one so I could see what it can do. Out of the box for about 1000-1200 it was pretty lame. I forget how much I paid, but it was in that range.
    I would note that I have CNC Mills also. Some retrofit by me, and some from the MFG and modified to suit my needs.
    Bob La Londe
    Jul 2014
    35
    very nice
    Jun 2013
    1041
    A router is designed to cut woods and plastics. A heavy duty router will also cut non ferrous metals. A mill is designed to cut all metals including steels/exotics. Router vs mill has nothing to do with the shapes it will cut. Just about any mill or router will cut 2d and 3d no problem if it is a 3 or more axis machine. Routers have much higher spindle speed on average then a mill also. Mills even higher speed spindle mills will be capable of much lower spindle speeds to allow efficient steel cutting. Mills are usually much heavier built and more rigidly designed.
    Ben
    Sent from my HTC6435LVW using Tapatalk
    Jul 2014
    35
    Ok, let me rephrase. If I up my budget to 10k, what is the best CNC machine I can get? Most likely needs to be 120V and can't be too tall (Bridgeport mill too large). I'm seeing Tormach and Syil. Any others I should check out. Tool change would be great, but not sure if you can get that in that price range.
Page 1 of 2 12
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. new "small size" benchtop cnc mill based on weiss wmd16v
    By ihavenofish in forum Benchtop Machines
    Last Post: 08-01-2011, 04:01 AM
  4. "Off the Shelf" Benchtop CNC Mills
    By jeffo2001 in forum Benchtop Machines
    Last Post: 03-06-2008, 02:44 PM
