Hello
I am working on a DMU 50 with B and C axis
I have a part again where have to incorporate inclined borings, however I don’t know exactly how I have to pivot the two angles after each other, 30 degree tilt angle and 57 degree turning angle.
Am I also doing it with the plane option or does it somehow continue incrementally afterwards?
What happens to the zero point- where do I move it to?
So far I always had the direct angles and I was able to write them into a Plane Spatial block
and I also had the appropriate entry points for zero-point shift!
Here on the outer edge dimensioned to Z 1.057;
3.2 pre-drilling point at the diameter 10, but on average 30 degrees as a 3D view?
the whole piece is clamped on the diameter of 6 (long side)
