588,227 active members*
4,233 visitors online*
Page 1 of 2 12
Results 1 to 20 of 40
    Mar 2006
    1625
    Linley Jig Bore
    I bought this little guy about 4 years ago. I paid $200 for it. Vintage 1968 machine #4167 it was used for one job and sat in the corner.I had it behind my house and cover it in grease.Now it in the basement and the grease is gone. This machine is so clean it can still hold tenths. That I think I'm just going to keep it the way that it is.The motor is a 220 3 phase should I get a phase converter or a new motor? or should I do a conversion to sometype of cnc. What do you think?
    Attached Thumbnails Attached Thumbnails linley 1.jpg   linley 2.jpg   linley 3.jpg   linley 4.jpg
    Jul 2005
    12177
    I think you should keep it in its original condition for nostalgic reasons. Machines of that nature and older are what formed the foundation for modern manufacturing. I often wish I could have kept some of the old machines I started my business with but a sixteen feet long turret lathe weighing 6 tons was a bit unwieldy to stick at the back of the garage.
    Get a phase convertor.
    Mar 2006
    1625
    Quote Originally Posted by Geof
    That the way I leaning. This machine is like museum quality is there any real deference in phase converters
    Jan 2006
    4396
    Beautiful Machine Mike
    Very Very Very Nice Mike. What Geof said, keep it the way it is and get a Phase Converter. You don't see those beautiful machines anymore. What type of tool holders does she take? I may have someone you can talk to.
    I can't get over how clean it is as I am droolling on the key board.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2006
    1625
    In need the following collet
    Modified collets and nosepiece of the Mk. 1A. Based on the Schaublin ESX design, these collets were developed with the express intention of providing a superior grip on the shanks of cutting tools.
    An important part of the new assembly was a freely-floating compensating washer which fitted between the collet and nose cap; this was intended to eliminate possible inaccuracies between the locknut thread and its inner surface which clamped against the collet.-info from Tony at http://www.lathes.co.uk/linley/page3.html
    Attached Thumbnails Attached Thumbnails collet linley.JPG   collet- 2.JPG   collet-3.JPG
    Mar 2006
    67
    I would use an inverter(VFD)...then you can vary the spindle speed electronicly. Most VFDs I have ever seen can be run single phase with no problems and used ones are cheap on ebay.
    edit: tell me what hp it is and I may have a VFD that would work for ya
    Mar 2006
    1625
    Quote Originally Posted by 70cyclone
    I would use an inverter(VFD)...edit: tell me what hp it is and I may have a VFD that would work for ya
    interesting Idea so the VFD would replace the phase converter. I can't find a tag on motor but 1hp max,I would think tell me more....I did do a search and read baldor site for some info on VFD but I real know nothing about VFD
    Mar 2006
    67
    well a VFD(variable frequency drive) is what most comercial CNC machines use to control spindle speed.
    most can be run single phase with a reduction in max output. if you find a 5hp drive you can program its current limit to run a 1hp without damage to the motor
    couple of ways to use them...
    1. just program it to always run 60hz and just have forward/stop/reverse hooked up. then it just runs at whatever the motor is wound for. (ie 1750rpm)
    2. set it up with a pot and be able to vary the speed from 0 to whatever max out is for the drive(ie 240hz) this is nice because on drill presses and such you don't have to change the belt for different spindle speeds.
    I prefer Yaskawa vector style drives for servos and VFDs and the build alot of other brands as well, like Omron, EMS, and others. I also like them because my Milltronics mill has them and I know the abuse they can take.
    Mar 2006
    67
    oh and you can get used 5hp or less VFDs on ebay for less than $100 really easy.
    this style is what I always try to find and have great luck with...
    Yaskawa V7 drives
    Dec 2003
    24220
    With a standard motor the maximum advisable frequency would be 120hz if its a 4 pole motor or 60hz if 2 pole.
    If this motor is 2 pole and you were to run it at 240 hz (14,400rpm), it would probabally disintegrate :violin: .
    Al.
    Albert E.
    Jan 2006
    4396
    Quote Originally Posted by lakeside
    Sorry Mike, the tool holders I had in mind are different. They have a type of Acme Thread at the top of the taper (something like a CAT30). :frown:
    Toby D.
    Schwarzwald
    Mar 2006
    1625
    Thanks for the info I found this one new for $260 it just the basic http://www.deselectric.com/inverters. The Yaskawa v7 drive might be a bit over kill on this one
    Mar 2006
    67
    not a bad deal...looks just like a yaskawa too...
    take a look at this...Mitsubishi drive on ebay
    Mar 2006
    1625
    I looked at the one on ebay output is only 5 amps that sounds a little on the low side. I'm just guess but 20 amps sound better. If I put the motor under heavy load would I not need the amps?
    Jul 2005
    12177
    One hp roughly speaking is 1kva, (A hp equals 746 watts to be exact so rounding to 1kva is generous). Three phase 220volts at 5amps is nearly 2kva so the 5amp one does give you enough. The calculation is 220v * 5amp * 1.732 = 1905va. The 1.732 is because it is three phase; single phase is just volts * amps.
    Because this is an inverter you would normally only run one motor at a time so getting a bigger one is not any benefit. With a rotary phase convertor getting one bigger than you need at this time is worth it because you can run more than one motor at the same time.
    Mar 2006
    1625
    ......With a rotary phase convertor getting one bigger than you need at this time is worth it because you can run more than one motor at the same time.
    It may be worth going with a rotary phase at this time as you say Geof. What size, if I wanted to run maybe 3 motors or less at a time. Less than 30hp total and by who I;ve seen Baldor
    Jul 2005
    12177
    Al The Man is the one to give you the definite answer. I think it works that if you have a 5 hp idler motor on the rotary phase converter you can run a total of 10 hp on it provided all the wires are the correct capacity. I think your 30hp total may be pushing it if you are connecting this into 120/240volt house wiring this would need around 100amps.
    Mar 2006
    1625
    just brought in new 200 amp service that for a small house I figuire if I add a small lathe and maybe a little toolroom cnc that where my guess 30hp came from and it's on the high side Thanks Geof think it time for Al
    Mar 2006
    67
    thing I don't like about phase converters is big and bulky, and not cheap if you want one 'cnc ready'
    I run my Milltronics cnc mill single phase and have VFDs on my lathe and grinder/buffers
    Mar 2006
    1625
    Well that caught my eye, Mostly I would spend more than $500 on a rotary where as the one I found for $268 would mostly meet my present needs How many real amps should the invertor kick out?Is there any advange of getting one with more amps so it could be switch between machines?
Page 1 of 2 12
  1. My linley Jig Borer- Pics and questions...
    By nate in forum Uncategorised MetalWorking Machines
    Last Post: 08-12-2015, 07:21 PM
  2. Iscar ETM ITS BORE help
    By ironlung29 in forum Diemaking / Diecutting
    Last Post: 08-25-2010, 01:14 PM
  3. chatter on bore out
    By kendo in forum MetalWork Discussion
    Last Post: 12-17-2008, 03:26 AM
  4. angled bore ?
    By pit202 in forum Solidworks
    Last Post: 11-03-2008, 02:11 AM
  5. Converting Linley Jig borer to CNC Mill.
    By nate in forum Gecko Drives
    Last Post: 12-12-2006, 04:29 AM
