Re: Running a 3 phase 208v compressor motor on 240v
Motors like transformers are fairly rugged items, but it is a tad over the recommended limit which is normally around 228.
You could try it and monitor the running current, both off and on load and compare to the FLA on the plate, if it is shown.
It will not affect any other part of the system, also you should have overloads and fusing in place to prevent a complete burn out.
Max.
Albert E.
